Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 19-03-20, 10:39 AM
RobCharles1981 RobCharles1981 is offline
Member
Graphics Card Problem
Hello all,
I have a problem with my Graphics Card at the moment which I have the XFX R9 390 which I've had for a good few years.
I use the latest graphics drivers but on various occasions I've been getting a BSOD with the stop code "Video TDR Failure" What failed: atikmpag.sys
Any ideas what is going on?
Thanks
Rob
__________________
AMD Ryzen 5 2600. MSI B450 Gaming Motherboard Corsair H60, Corsair Vengenance LPX 16gig DDR3
Corsair TX 750m PSU, AMD R9 390: Creative Soundblaster Z: Fractal R5 Case
  #2
Old 19-03-20, 11:19 AM
WYP's Avatar
WYP WYP is online now
News Guru
Are you doing anything specific when it crashes?
Have you tried using a program like DDU (Display Driver Uninstaller) to uninstall your driver and install them again?
__________________
_______________________________
Twitter - @WYP_PC
  #3
Old 19-03-20, 11:38 AM
Member
Hi I'm doing nothing of the ordinary, loading up firefox for example, then the screen flickers so many times.
Yep I've used that program too to clean install the drivers as well.
Here is a screen dump error from event viewer:
Faulting application name: Radeonsoftware.exe, version: 10.1.2.1788, time stamp: 0x5e59a285
Faulting module name: ntdll.dll, version: 10.0.18362.719, time stamp: 0x64d10ee0
Exception code: 0xc0000374
Fault offset: 0x00000000000f92a9
Faulting process id: 0x3158
Faulting application start time: 0x01d5fdd6b2f88d0c
Faulting application path: D:\Program files\CNext\CNext\Radeonsoftware.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 23d50d60-03de-4bfd-89cf-e7bfd0ed519c
Faulting package full name:
Faulting package-relative application ID
__________________
  #4
Old 19-03-20, 01:02 PM
WYP's Avatar
News Guru
Not sure. It might be best to regress to an older driver for now.
Report your issue to AMD and they will hopefully fix it with their next driver release, though someone else here may know what's wrong.
https://www.amd.com/report
Update -
AMD has a new driver today. Maybe it will fix your issue.
https://www.overclock3d.net/news/sof...lyx_and_more/1
__________________
Twitter - @WYP_PC
  #5
Old 22-05-20, 07:53 AM
Member
Its now still doing it.
I don't think it's a driver problem it's more related to a hardware problem!
__________________
  #6
Old 22-05-20, 11:41 AM
Damien c Damien c is offline
OC3D Elite
Looking around on the net, it seems quite a few people are suffering with this type of issue.
Some have resolved it by disabling hardware acceleration in browsers, others have had to reduce Vram clockspeed and even try undervolting there cards.
It might be worth trying those to see if it resolves it.
__________________
Gaming PC: AMD 3950X, 32GB Corsiar DDR4, MSI 2080Ti, WD Black 1TB NVME
Server PC: 2700x, 16GB Corsair DDR4, MSI GTX 1660Ti, Gigabyte 120Gb M.2, Crucial 240Gb SSD, WD Blue 500Gb SSD, 2x Seagate 6Tb HDD's
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
