Go Back   OC3D Forums > [OC3D] Customer Care Forums > NZXT Forum
  #1
Old 21-02-13, 06:15 AM
USAdystopia USAdystopia is offline
Newbie
Fz 200 fans
When can we expect the FZ 200 fans to be available?
  #2
Old 21-02-13, 06:33 AM
FredEx's Avatar
FredEx FredEx is offline
OC3D Crew
From what I had read they became available Feb 19.
__________________
R.I.P. Larry William Ross (Big Brother)16/6/1948 to 16/6/2013
R.I.P. Elizabeth Jane Durham Ross Curry (Mom) 9/6/25 to 30/7/2017
  #3
Old 21-02-13, 08:19 AM
mastercrim mastercrim is offline
Newbie
soon as i can find someone selling them im placing a order but no luck with that yet
  #4
Old 21-02-13, 08:52 AM
Mark3Max Mark3Max is offline
OC3D Crew
Yeah I'd like to find one too, but Amazon or Newegg don't have them listed yet.
__________________
Corsair 650D, MSI Z77A-GD65 , I7-3770k, Corsair H100i w/sp120 QE ,G.Skill Ares 16gb 2133 c9, Asus Blu-Ray Burner, Asus Xonar STX ,Corsair Neutron GTX 240gb ,W.D. black 1TB ,Seagate 3TB, MSI GTX 680 Lightning, Corsair AX760i ,Case Fans : Front : CM 200 blue,Rear : Corsair AF 120 PE , Klipsch 2.1 , Sennheiser HD650 , 2 x Samsung 23" 1080p , Logitech G710+
  #5
Old 27-02-13, 03:51 PM
Jason-CL's Avatar
Jason-CL Jason-CL is offline
Caselabs Rep
I believe they started shipping on the 19th, which there's usually a 2-3 week lead time after that.
__________________
NZXT Forum Rep.
  #6
Old 27-02-13, 10:44 PM
NRG!'s Avatar
NRG! NRG! is offline
Advanced Member
Make sure they fit in your 600t before you buy them
There's no standards for size and mounting above 140mm fan iirc.
  #7
Old 03-03-13, 06:36 AM
Newbie
Well, that actually is a good point...looks as they have the same specs as what is currently installed...guessing would have to make them fit IF they don't.
  #8
Old 03-03-13, 11:10 AM
NRG!'s Avatar
Advanced Member
NZXT might be able to provide you with a schematic diagram for the fan.
Bitfenix have them on their site for the 200/230mm spectre pros
  #9
Old 05-03-13, 02:31 AM
Jason-CL's Avatar
Caselabs Rep
I'm looking into it to see if we can get dimensions up for them.
__________________
NZXT Forum Rep.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
