Go Back   OC3D Forums > [OC3D] Forum Teams > [OC3D] Benchmark Team
Thread Tools Display Modes
  #1
Old 23-11-17, 07:09 PM
WYP's Avatar
WYP WYP is offline
News Guru
3DMARK Fire Strike and Time Spy Benchmark Thread
3DMARK is currently available for £3.44 on Steam, making this the perfect opportunity to get into some benchmarking action.
In this thread, we will be testing both Time Spy (DX12) and Fire Strike (DX11) using both the tool's standard and 4K tests.
Ground Rules
These rules come courtesy of Kaapstad's old 3DMARK Thread (I don't feel the need to change what has already been proven to work well)
Please -
- If your CPU has integrated graphics remember to turn this off.
- No entries with the time data error message can be accepted.
- Post your CPU and GPU clocks.
- Post your Time Spy link.
- Post the drivers in use.
Please post results in the following format:
Final Score, GPU, GPU Clock speeds, GPU Score, CPU Score, CPU Uses,
CPU Clock speeds, username, link to results, GPU driver used.
6812, 980 Ti @1550/2103, GPU Score 6323, CPU Score 12145, 6950X @4.4, Kaapstad, - Link 368.39
Using this format will make updating this thread a lot easier. You do not need to colourise the text.
Single GPU Charts
Fire Strike
1. 32231, TitanV @2047/1066, GPU Score 36525, CPU Score 36418, 7980XE @4.8, Kaapstad, - Link 388.59
2. 27709, 1080Ti @2050/3002, GPU Score 30148, CPU Score 34749, 7980XE @4.6, Kaapstad, - Link 388.13
3. 22714, GTX 1080 FE @ 2152MHz Core 5560MHz Memory, GPU Score 24903, CPU Score 26945, Intel i9-9900K @ 5.1GHz, Ofan, - Link 417.22
4. 23281, GTX Titan Xp (CE) @ 1911MHz (max. boost) / 1604MHz , GPU Score 32082, CPU Score 18035, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 445.87
5. 22613, Titan X (Pascal) @2050MHz, GPU Score 30,128, CPU Score 19265, Intel Xeon (14C/28T) @ 2.8GHz, AlienALX, - Link 388.13
5. 20489, GTX 1080 Fe @ 2101MHz core (max. boost) / 5568MHz, GPU Score 24686, CPU Score 19393, Xeon E5-1680 v2 @ 4.4GHz, agent_x007, - Link 416.16.
6. 19505, GTX 1080 Fe @ 2012MHz core (max. boost) / 5508MHz, GPU Score 23233, CPU Score 18996, Xeon E5-1680 v2 @ 4.3GHz, agent_x007, - Link 411.63
7. 19301, Vega 56 @1721/1075, GPU Score 24516, CPU Score 18673, 1920X @4.0 (6C/12T), Kei, - Link 17.11.2
8. 18735, 1080Ti @1987/1377, GPU Score 29591, CPU Score 10918, 4790k @4.0, Wraith, - Link 388.31
9. 15888, GTX Titan X (Maxwell) @ 1178MHz (max. boost) / 1753MHz , GPU Score 17591, CPU Score 18861, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 417.71
10. 10990, GPU GTX 780 @1202/1851, GFX Score 11927, Physics Score 23859, CPU 1920X @3.965, Kei - Link 385.69
11. 10894, GTX 970 1561 core/1901 mem, GPU Score 13777, CPU Score 8654, 4690k @4.4GHz, looz, - Link 388.13
12. 10832, GTX Titan Black @ 1059MHz (max. boost) / 1750MHz , GPU Score 11879, CPU Score 19140, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 416.16
13. 4529, GTX 580 3GB @ 772MHz/1002MHz , GPU Score 4780, CPU Score 19132, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 391.35
Fire Strike Ultra (4K)
1. 9440, TitanV @2047/1066, GPU Score 9108, CPU Score 35602, 7980XE @4.8, Kaapstad, - Link 388.59
2. 7947, GTX Titan Xp (CE) @ 1911MHz (max. boost) / 1604MHz , GPU Score 7963, CPU Score 18397, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 445.87
3. 6790, GTX 1080 Ti @1987/1377, GPU Score 7033, CPU Score 10898, i7 4790K, Wraith, - Link 388.31
4. 5746, Vega 56 @1727/1100, GPU Score 5866, CPU Score 18462, 1920X @3.975 (6C/12T), Kei, - Link 17.11.4
5. 5600, GTX 1080 Fe @ 2012MHz core (max. boost) / 5508MHz, GPU Score 5533, CPU Score 19014, Xeon E5-1680 v2 @ 4.3GHz, agent_x007, - Link 411.63
6. 4261, GTX Titan X (Maxwell) @ 1178MHz (max. boost) / 1753MHz , GPU Score 4158, CPU Score 18844, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 417.71
7. 2636, GTX Titan Black @ 1059MHz (max. boost) / 1750MHz , GPU Score 2544, CPU Score 19095, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 416.16
8. 1098, GTX 580 3GB @ 772MHz/1002MHz , GPU Score 1056, CPU Score 19142, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 391.35
Time Spy
1. 14809, TitanV @2010/1067, GPU Score 14941, CPU Score 14104, 7980XE @4.8, Kaapstad, - Link 388.59
2. 10614, GTX Titan Xp (CE) @ 1911MHz (max. boost) / 1604MHz , GPU Score 10979, CPU Score 8935, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 445.87
3. 10059, Titan X (Pascal) @2050MHz, GPU Score 10255, CPU Score 9077, Intel Xeon (14C/28T) @ 2.8GHz, AlienALX, - Link 388.13
4. 8642, GTX 1080 FE @ 2164MHz Core 5508MHz Memory, GPU Score 8233, CPU Score 12037, Intel i9-9900K @ 5.1GHz, Ofan, - Link 417.22
5. 8280, 1080Ti @1974/1377, GPU Score 9904, CPU Score 4293, 4790k @4.0, Wraith, - Link 388.31
6. 8375, GTX 1080 Fe @ 2114MHz core (max. boost) / 5568MHz, GPU Score 8245, CPU Score 9203, Xeon E5-1680 v2 @ 4.4GHz, agent_x007, - Link 416.16
7. 8306, RTX 2060 FE @2040/1938, GPU Score 8242, CPU Score 8691, 8700K @4.7, looz, - Link 417.35
8. 8035, Vega 56 @1722/1165, GPU Score 7877, CPU Score 9068, 1920X @4.15, Kei, - Link 18.5.1
9. 8023, GTX 1080 Fe @ 2012MHz core (max. boost) / 5508MHz, GPU Score 7864, CPU Score 9067, Xeon E5-1680 v2 @ 4.3GHz, agent_x007, - Link 411.63
10. 7891, Vega 56 @1727/1100, GPU Score 7725, CPU Score 8990, 1920X @3.975, Kei, - Link 17.11.4
11. 7808, Vega 56 @1717/1075, GPU Score 7618, CPU Score 9102, 1920X @4.0, Kei, - Link 17.11.2
12. 5765, GTX Titan X (Maxwell) @ 1178MHz (max. boost) / 1753MHz , GPU Score 5415, CPU Score 9111, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 417.71
13. 4486, GTX 970 @1537/1858, GPU Score 4117, CPU Score 9127, [email protected], looz, - Link 388.71
14. 3940, GTX Titan Black @ 1202MHz (max. boost) / 1851MHz , GPU Score 3583, CPU Score 9064, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 417.71
15. 3613, GTX 780 @1202/1851, GFX Score 3298, CPU Score 7880, CPU 1920X @4.015, Kei - Link 385.69
16. 951, GTX 580 3GB @ 772MHz/1002MHz , GPU Score 822, CPU Score 8990, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 391.35
Time Spy Extreme (4K)
1. 7944, TitanV @2002/1066, GPU Score 7552, CPU Score 11258, i9 7980XE @4.8, Kaapstad, - Link 388.59
2. 5370, 1080Ti @2038/3002, GPU Score 4930, CPU Score 10891, i9 7980XE @4.6, Kaapstad, - Link 388.13
3. 5361, Titan Xp @2050/3106, GPU Score 5351, CPU Score 5423, i7 6950Xk @4.4, Kaapstad, - Link 388.13
4. 4826, GTX Titan Xp (CE) @ 1911MHz (max. boost) / 1604MHz , GPU Score 5180, CPU Score 3479, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 445.87
5. 4422, 1080 TI @2000/5900, GPU Score 4912, CPU Score 2827, i7 7700k @5ghz, FTLN, - Link Driver 390.65
6.4299, EVGA GTX 1080 Ti SC Black @1974MHz, GPU Score 4799, CPU Score 2705, i7 7700K @ 5.0GHz, , - Link 388.71
7. 3836, Vega 56 @1727/1100, GPU Score 3683, CPU Score 5021, 1920X @3.975, Kei, - Link 17.11.4
8. 3780, 1080Ti @1962/1377, GPU Score 4628, CPU Score 1855, 4790k @4.0, Wraith, - Link 388.31
9. 3706, GTX 1080 Fe @ 2114MHz core (max. boost) / 5568MHz, GPU Score 3750, CPU Score 3479, Xeon E5-1680 v2 @ 4.4GHz, agent_x007, - Link 416.16
10. 2707, GTX Titan X (Maxwell) @ 1178MHz (max. boost) / 1753MHz , GPU Score 2602, CPU Score 3520, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 417.71
11. 1856, GTX Titan Black @ 1202MHz (max. boost) / 1851MHz , GPU Score 1714, CPU Score 3510, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 417.71
12. 501, GTX 580 3GB @ 772MHz/1002MHz , GPU Score 436, CPU Score 3491, Xeon E5-1680 v2 @ 4.3, agent_x007, LINK, 391.35
Multi-GPU Charts
Fire Strike
1. 27023, 1080 Ti x2 @2085/1514, GPU Score 49533, CPU Score 20459, R7 1700 @3.9, Bartacus, - Link 388.13
1. 5,061, 1080 x2, GPU Score 5,057, CPU Score 22,562, i9 7900X, realneil, - Link 388.31
Time Spy
1. 17153, 1080 Ti x2 @2085/1514, GPU Score 20515, CPU Score 8895, R7 1700 @3.9, Bartacus, - Link 388.131.
2. 12,766, 1080 x2, GPU Score 13,204, CPU Score 10,748, i9 7900X, realneil, - Link 388.31
1. 13734, Titan Xp x4 @2012/3106, GPU Score 18790, CPU Score 5440, i7 6950Xk @4.4, Kaapstad, - Link 388.13
2. 12046, Titan Xp x3 @1974/3106, GPU Score 15329, CPU Score 5442, i7 6950Xk @4.4, Kaapstad, - Link 388.13
3. 9200, Titan Xp x2 @2038/3103, GPU Score 10480, CPU Score 5437, i7 6950Xk @4.4, Kaapstad, - Link 388.13
4. 7882, 1080 Ti x2 @2085/1514, GPU Score 9944, CPU Score 3624, R7 1700 @3.9, Bartacus, - Link 388.13
5. 6,263, 1080 x2, GPU Score 6,263, CPU Score 5,425, i9 7900X, realneil, - Link 388.31
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 23-11-17, 07:15 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
First into the fray
Time spy.
Time spy 4K
Fire Strike
Fire Strike Extreme
12086, 1080Ti @1974/1377, GPU Score 14136, CPU Score 10899, 4790k @4.0, Wraith, - Link 388.31
Fire Strike Ultra
6790, 1080Ti @1987/1377, GPU Score 7033, CPU Score 10898, 4790k @4.0, Wraith, - Link 388.31
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #3
Old 23-11-17, 08:45 PM
Kei's Avatar
Kei Kei is offline
OC3D Crew
Time spy.
Fire Strike
__________________
Gigabyte Aorus X399 Gaming 7 ⁞⁞ Ryzen TR 1920x ⁞⁞ EK Blocks + αcool XT45 rads ⁞⁞ AMD Radeon Vega 56 ⁞⁞ 32GB 8 Pack 3200C14 ⁞⁞ Enthoo Primo
Seasonic Prime 750W ⁞⁞ Polaris 961 256GB ⁞⁞ 850 Pro 512GB ⁞⁞ M500 240GB ⁞⁞ WD Se 4TB & 1TB x2 ⁞⁞ Samsung C27HG70 + Dell 2408WFP
Ducky Shine 5 ⁞⁞ AJA Kona LSe ⁞⁞ RME HDSPe AIO ⁞⁞ Marantz AV7701 ⁞⁞ Tannoy SRM 10B ⁞⁞ AKG K601 ⁞⁞ Beyer DT770
  #4
Old 24-11-17, 08:52 AM
Kaapstad's Avatar
Kaapstad Kaapstad is offline
OC3D Elite
Score 5 361
Titan Xp(1x) @2050/3106
Intel Core i7-6950X @4.4
Graphics Score 5 351
CPU Score 5 423
Drivers 388.13
https://www.3dmark.com/spy/2730489
Score 9 200
With NVIDIA Titan Xp(2x) @2038/3103
And Intel Core i7-6950X @4.4
Graphics Score 10 480
CPU Score 5 437
Drivers 387.92
https://www.3dmark.com/spy/2544483
Score 12 046
NVIDIA Titan Xp(3x) @1974/3106
Graphics Score 15 329
CPU Score 5 442
Drivers 388.13
https://www.3dmark.com/spy/2710891
Score 13 734
NVIDIA Titan Xp(4x) @2012/3106
Graphics Score 18 790
CPU Score 5 440
Drivers 388.13
https://www.3dmark.com/spy/2730063
__________________
OC3D Overclockers Club Member
#041
GTX 960 owner and proud of it.
  #5
Old 24-11-17, 04:52 PM
WYP's Avatar
WYP WYP is offline
News Guru
The scoreboard has been updated. Please use the proper submission format, as updating the list will take far too long otherwise.
__________________
Twitter - @WYP_PC
  #6
Old 25-11-17, 01:04 AM
Bartacus Bartacus is offline
OC3D Elite
Hope this is formatted properly!
Fire Strike:
27023, 1080Ti*[email protected]/1514, GPU Score 49533, CPU Score 20072, [email protected], Bartacus, http://www.3dmark.com/fs/14237435 , 388.13
Fire Strike Extreme:
20799, 1080Ti*[email protected]/1514, GPU Score 28234, CPU Score 20459, [email protected], Bartacus, http://www.3dmark.com/fs/14237399 , 388.13
Time Spy:
17153, 1080Ti*[email protected]/1514, GPU Score 20515, CPU Score 8895, [email protected], Bartacus, http://www.3dmark.com/spy/2799178 , 388.13
Time Spy Extreme:
7882, 1080Ti*[email protected]/1514, GPU Score 9944, CPU Score 3624, [email protected], Bartacus, http://www.3dmark.com/spy/2799270 , 388.13
__________________
Guts: ThreadRipper 2950X / GB Aorus Xtreme X399 / 64GB TridentZ Royal 3600CL16 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU
Storage: 6TB RAID0 NVME array (ADATA SX8200 Pro 2TB x 3)
Water Cooling: HeatKiller TR4-Pro CPU block / HeatKiller IV GPU blocks / 360mm Darskide LP360 rads x 3 / Heatkiller reservoir
  #7
Old 25-11-17, 10:24 AM
WYP's Avatar
WYP WYP is offline
News Guru
Fire Strike:
Time Spy:
Time Spy Extreme:
In this thread, I am not recording 3DMARK Fire Strike Extreme, just the basic version and the 4K version.
__________________
Twitter - @WYP_PC
  #8
Old 25-11-17, 01:50 PM
Wraith's Avatar
Bettyswollocks
Would it not be better to have multiple card setups on their own like before as it's confusing.
__________________
  #9
Old 25-11-17, 05:20 PM
WYP's Avatar
WYP WYP is offline
News Guru
Aye, that might be the best option.
__________________
Twitter - @WYP_PC
  #10
Old 25-11-17, 08:53 PM
looz's Avatar
looz looz is offline
OC3D Elite
Time to snatch the last spot on the regular Fire Strike chart.
10894, GTX 970, 1561Mhz core / 1901Mhz memory, 13777, 8654, 4690k, 4.4GHz, looz, https://www.3dmark.com/fs/14179359, 388.13 WHQL
__________________
i7 8700k - 16GB - 2060 FE - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
