Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 05-05-12, 11:08 PM
piotrekhc piotrekhc is offline
Advanced Member
I think they low xD
Click image for larger version
__________________
Liberate Te ex Inferis
  #2
Old 06-05-12, 02:41 AM
TheOsTech TheOsTech is offline
Newbie
[sharedmedia=core:attachments:4368]
[sup]I get about 22-30 with idle 1.195 vcore no speedstep so 3500ghz.[/sup]
[sup]The nh d14 works well on the 3770k even at 4.4 hardly got above 70 and mostly stayed at around 50-60's during ibt.[/sup]
[sup]EDIT: what cooler are you using? have you tried overclocking?[/sup]
  #3
Old 06-05-12, 03:14 AM
Matthias2437 Matthias2437 is offline
Advanced Member
Not bad at all. I get 17-19 idle on my Phenom 2 1090t @ 4.00 ghz.
  #4
Old 06-05-12, 03:55 AM
Murphyslaw Murphyslaw is offline
Member
Originally Posted by piotrekhc View Post
I think they low xD
Am I seeing that image correctly?, or is it just me. 100*16 multi = 1600MHz and ~1.00V CPU VCore
__________________
current rig
  #5
Old 06-05-12, 07:02 AM
Ru5ty_t00l's Avatar
Ru5ty_t00l Ru5ty_t00l is offline
OC3D Crew
Originally Posted by Matthias2437 View Post
Not baad at all. I get 17-19 idle on my Phenom 2 1090t @ 4.00 ghz.
what's ur room temperature?
__________________
I'm a player Not a payer
I'm a Greek not a geek
  #6
Old 06-05-12, 07:05 AM
KING_OF_SAND KING_OF_SAND is offline
OC3D Elite
In the winter I can get my CPU (1090t stock) idle temp in the single digits with a stock cooler
  #7
Old 06-05-12, 12:38 PM
marsey99 marsey99 is offline
OC3D Elite
amd temps lie, mine tried to tell me it was under 20c on the cores when the room was warmer lol
depends upon your ambient temp dude but with speedstep kicking it won to 1.6ghz on 1.0v it will run cool.
my 25k @4.5ghz all the time stays under 25c idle in 20ish c ambient.
  #8
Old 06-05-12, 01:07 PM
ruthless_villain's Avatar
ruthless_villain ruthless_villain is offline
OC3D Elite
My fx-8120 reckons its at 3 degrees sometimes... It loads at 8 degrees lol
__________________
  #9
Old 06-05-12, 01:48 PM
Advanced Member
Normally about 1c higher than my CPU temp. Using the H100 with Noctuas. Also I didn't have to increase voltage on my 1090t to get my 4.00 ghz overclock stable so that isn't making produce too much more heat.
  #10
Old 07-05-12, 07:44 AM
Member
how can your room temperature be higher then your CPU's unless your going to all lengths with cooling.
my rig sits around 4C above ambient and that is with water cooling and on base Vcore. How ever over clocked it sits a bit higher.
__________________
current rig
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
