Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #1
Old 30-09-19, 01:06 PM
WYP's Avatar
WYP WYP is offline
News Guru
Intel's next-gen architecture will be "significantly bigger" than Sunny Cove
Should AMD be worried?
Read more about Intel's next-gen CPU architecture being "significantly bigger" than Sunny Cove.
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 30-09-19, 02:44 PM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
It all depends on pricing, if Intel keeps pushing high prices then AMD has nothing to really be worried about, and even then AMD is more likely to drop prices to keep the sales up.
  #3
Old 30-09-19, 02:48 PM
Damien c Damien c is online now
OC3D Elite
Personally for me it would depend on whether they have fixed the security bugs, can get the temps and power draw under control as well as actually make the cpu's worth the price.
Maybe then AMD might have something to worry about but if Intel don't do those things then AMD have nothing to worry about.
__________________
  #4
Old 30-09-19, 04:32 PM
looz's Avatar
looz looz is offline
OC3D Elite
16nm
__________________
i7 8700k - 16GB - 2060 FE - 512GB 970 & 850 EVO - AKG K702
  #5
Old 30-09-19, 06:34 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
As long as there's a performance increase from my current 9900K I don't really care if it's on 14nm+++++++++++++++++++++++++++++++++ as long as the performance increase is there, Although having said that I highly doubt I'll need to upgrade for at least another release or 2.
__________________
=Origin-Steam-Uplay-XBLive - Dicehunter=
  #6
Old 30-09-19, 07:30 PM
WYP's Avatar
WYP WYP is offline
News Guru
The big question ATM is if Intel's IPC gains will be ate up by clock speed regressions. Sunny Cove hasn't looked very promising so far in this regard. Hopefully things will get better.
I can't wait to see AMD release 7nm mobile CPUs. That will mark a big change for AMD!
__________________
Twitter - @WYP_PC
  #7
Old 30-09-19, 07:43 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
This is exactly it for me personally.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
