Go Back   OC3D Forums > [OC3D] General Forums > OC3D Reviews & Videos
Thread Tools Display Modes
  #21
Old 10-08-17, 11:38 PM
Soheil Soheil is offline
Newbie
Question hi to all
hi
i have 1 question please answer me
what is exactly this RT update? this is for bios or windows or...?
& what if we dont want this? this update make Ryzen weaker Especially in 1600X
please help us
  #22
Old 10-08-17, 11:58 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
OC3D Elite
Send a message via Skype™ to Dicehunter
Originally Posted by Soheil View Post
hi
please help us
This is to re-test after the bios updates, If you don't want it then don't update your bios.
__________________
=Steam - Dicehunter = Origin - Dicehunter - Uplay - DicehunterUPLAY=
  #23
Old 30-09-17, 09:32 PM
realneil's Avatar
realneil realneil is offline
OC3D Crew
Good review. A retest may not have been necessary, but it's appreciated. It was a good read.
I worked on my Ryzen 1700X system for about two weeks when it was brand new. It was a PITA to have to mess with it, but once the newest BIOS was released, I got 3.99GHz. CPU and 2988MHz RAM speed with my Crosshair VI board.
Then, I buttoned it up and have been using it like that ever since. It's rock solid and completely stable too.
I like it so much that I just bought a Ryzen 1600 and an ASUS Strix B350-F Gaming setup to upgrade my wife's PC. It will be set to run at stock speeds with a GTX-980Ti inside.
__________________
  #24
Old 10-12-17, 07:26 PM
RobM's Avatar
RobM RobM is offline
OC3D Crew
Tom have you done a review on the Asus B350-F Strix, I have searched high and low and am unable to find anything.
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Stock Cooler | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 140gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #25
Old 10-12-17, 08:13 PM
MacLeod's Avatar
MacLeod MacLeod is offline
OC3D Elite
This is a good overview of most all AM4 motherboards.
https://www.gamersnexus.net/guides/3...king-x370-b350
__________________
AMD R5 1600X @ 4.0 GHz ••• Asus ROG Strix X370-F ••• Corsair H110i
Corsair 500R ••• EVGA Supernova G3 750 ••• Corsair Vengeance 16GB
Western Digital Caviar Black 1TB x2 ••• MSI R9 290x Lightning
Samsung 840 Evo 250GB ••• BenQ XL2720Z @ 144 Hz
Razer BlackWidow Ultimate ••• Razer DeathAdder
  #26
Old 10-12-17, 08:22 PM
RobM's Avatar
OC3D Crew
Edit already seen that video, was hoping for one by Tom as I trust his opinion
I am looking at getting R5 1600 and either the x370 pro of the B350-F Strix
__________________
  #27
Old 10-12-17, 08:25 PM
AMD Enthusiast
Originally Posted by RobM View Post
thank you, will take a look at that, was hoping for one by Tom as I trust his opinion
AFAIK the board you are looking into is probably the best all around B350 board. Also pretty much the most expensive.
__________________
"I would have followed you, my Captain, my King."
- Boromir's last words.
  #28
Old 10-12-17, 08:29 PM
RobM's Avatar
OC3D Crew
indeed and I really like the looks of it over the 370 boards at similar price points
__________________
  #29
Old 10-12-17, 08:33 PM
realneil's Avatar
OC3D Crew
Rob, I have that board and it works fine. I used a 32GB kit of Kingston HyperX 2400MHz RAM in it and it automagically set it to the proper speed right out of the box.
The RGB effects are working right as well.
I had ordered a Ryzen 1600 CPU to use in it, but I ended up with a Ryzen-5 1500X instead. (long story)
While performance is good, it isn't what I was looking for. It's not the fault of the board though. I'm tempted to put my 1700X in there to see how that goes.
Performance is pretty good as long as you plan to run at stock, or close to stock speeds with it. It looks good with the black PCB and brushed grey metal heatsinks too.
It just works out of the box, without troubles.
__________________
  #30
Old 10-12-17, 08:38 PM
RobM's Avatar
OC3D Crew
Cheers buddy, I intend to pair it with a 1600 and 16gb 3200 ram with a modest oc only
most the boards are eithe matx which I dont like or garishly red coloured so need either a board with some blue in it or a neutral/black look
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
