Go Back   OC3D Forums > [OC3D] Customer Care Forums > Asus UK Customer Care Forums
Thread Tools Display Modes
  #1
Old 31-07-20, 09:19 AM
Cynthia Zeigler Cynthia Zeigler is offline
Newbie
Asus Vivobook laptop - Installing another RAM
Hello again, My sissy has an Asus Vivobook laptop with 4 GB DDR4 2400MHz SDRAM Onboard memory, I bought another ram card yesterday from an online shop with the same amount of 4GB memory but I noticed it has different speed (aprx. 2666MHz) do I need to worry about installing it since it has different speeds? What are the cons and pros of mixing rams with different speeds?
  #2
Old 31-07-20, 09:53 AM
WYP's Avatar
WYP WYP is online now
News Guru
RAM sticks can run at speeds that are lower than their listed speeds, so you can run this RAM at 2400MHz with no problems.
Depending on the CPU that you use, your notebook may be limited to 2400MHz speeds anyway.
You will be fine installing it, but you will have to set them to the same speeds (2400MHz).
__________________
_______________________________
Twitter - @WYP_PC
  #3
Old 04-08-20, 09:14 AM
Newbie
Mmmm... Right. Thank you WYP.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
