Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section > Drivers
Thread Tools Display Modes
  #11
Old 11-10-12, 10:03 PM
marcus1987 marcus1987 is offline
Member
hi yer all my drivers are up to date i have the following
2600k
gtx670
16gb ram
what els you like
  #12
Jeremy1998's Avatar
Jeremy1998 Jeremy1998 is offline
Advanced Member
2600k
gtx670
16gb ram
what els you like
if all drivers are up to date, then you should not be lagging with that spec. I don't know what's wrong. It may be that xpadder may be the problem.
  #13
Old 11-10-12, 10:04 PM
dugdiamond's Avatar
dugdiamond dugdiamond is offline
OC3D Elite
if it is a controller that came with the xbox, then that is your problem
but.... buying a xbox360 controller for the PC will work on both
__________________
Prepare for the worst. Assume losing. Then... if the opposite occurs... BONUS!
  #14
Old 11-10-12, 10:05 PM
Member
Question
Originally Posted by PEXON View Post
Sorry to hear that dude! You can manage typing OK but not gaming then?
yer not that this is the issue but it is i cant play for long time on mouse and keybored as my hands lock up so i got a pad so i can play for hours lol
but i am looking at new keybored and mouse as the ones i have r crap and also the keypad any good
  #15
Old 11-10-12, 10:06 PM
Member
i was thinking that as it is fine on bf3
  #16
Old 11-10-12, 10:07 PM
Member
the one i have is made for window it says it on the box
and also i dont no y but my mouse is lagging as well
  #17
Old 11-10-12, 10:08 PM
Jeremy1998's Avatar
Advanced Member
Your mouse is lagging? In the game only, or like right now on the internet? The first thing to try would be to restart your computer.
  #18
Old 11-10-12, 10:12 PM
jamesriley94 jamesriley94 is offline
OC3D Elite
I had the same issues when I used to use controllers. For some games, they just do that, especially on the low sensitivities.
Try playing on a higher sensitivity.
If that doesn't work, try disabling controller support and use xpadder to program all your keys in, which then emulates a mouse movement and so should be smooth
  #19
Old 11-10-12, 10:13 PM
PEXON's Avatar
PEXON PEXON is offline
SleevingMaster
Send a message via Skype™ to PEXON
I was going to say, I used to plug my old XBOX controller in my PC to fly heli's in BF3 no issues, it just plugged and played.
__________________
El Jefe of Sleeving
  #20
Old 11-10-12, 10:20 PM
Member
no issuse with bf3 like u say plug and play but mw3 i get lag but i get it with mouse as well
and it is fine till i play mw3
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
