Go Back   OC3D Forums > [OC3D] Hardware & Software > Sound Cards & Speakers
Thread Tools Display Modes
  #1
Old 17-04-10, 12:41 PM
mrapoc mrapoc is offline
OC3D Elite
6x9s for car
Hey guys
I got two 5" speakers in the passenger doors of my car - now i need some bass!
Its a citroen ax so other than the two in the passenger doors, i only really have the parcel shelf.
I have a kenwood something or other with 4x50w channels and a preout or two, but i wont be going sub due to the already small boot and it will prolly get nicked!
Recommendations?
I got a limit of £50
__________________
  #2
Old 17-04-10, 01:38 PM
JN JN is offline
OC3D Elite
many many moons ago me and my ex had an older version pair of these on the rear shelf.
http://cgi.ebay.co.uk/Sony-Xplod-XS-...item2559f00134
Did the job nicely for a while.
  #3
Old 17-04-10, 01:44 PM
OC3D Elite
Cheers mate
will check em out
__________________
  #4
Old 17-04-10, 01:48 PM
Ghosthud1's Avatar
Ghosthud1 Ghosthud1 is offline
OC3D Elite
i can vouch for the sony xplods as i have two on my parcel shelf
also consider apline
http://www.halfords.com/webapp/wcs/s...egoryId_165707
i have two 13" in my front doors and they are massively bassy
__________________
  #5
Old 17-04-10, 02:20 PM
FarFarAway FarFarAway is offline
Newbie
JBL GT series kick out a hell of a lot of bass. The Xplod series are decent and Alpine make some very nice higher end speakers.
We were wiring one of my mate's cars up and picked up some Alpine components. Driver, mid and tweeter. Clean bass, clear midrange and decent highs. If you don't mind laying out a little more than the 'normal' 6x9s, then I highly recommend doing that.
Oh, and make you're own parcel shelf out of some solid MDF and acoustic cloth (cheap to buy, Halfords stock it I think). It improves the sound from car speakers no end.
I've wired up a few cars with decent audio, a good parcel shelf makes a huge difference and is really easy to do if you model it on the one in there already.
  #6
Old 17-04-10, 02:35 PM
OC3D Elite
may look into that but im just looking for somethin to tide me over before i sell it end of the year kinda thing.
ill be stealthing them using some acoustic cloth tho, as the parcel shelf has a dipped bit where i can literally stretch some cloth across hiding any evidence of speakers
__________________
  #7
Old 17-04-10, 04:09 PM
tinytomlogan's Avatar
The Guvnor
Just need to remember 6x9's are designed for the parcel shelf dude, not in the doors or owt.
Sonys are very good for the wedge tbh. Remember to use some baton or mdf strips to strengthen the pacel shelf too.
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #8
Old 17-04-10, 07:50 PM
ppuff ppuff is offline
Member
on the hiding, even cheap speakers look fancy these days and may draw unwanted attention. I remember always being a fan of bazooka tubes for some bumpin bass in my days, strap em to the back seat in the trunk and BOOOOM!
  #9
Old 18-04-10, 10:29 AM
Youngie1337 Youngie1337 is offline
OC3D Elite
Oldskool! I remember these from back in the day lol.
  #10
Old 18-04-10, 08:38 PM
OC3D Elite
think ill be getting those if all goes according to plan
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
