Go Back   OC3D Forums > [OC3D] Project Logs & Gallery > Rig Gallery
Thread Tools Display Modes
  #21
Old 09-12-13, 12:31 AM
Remmy's Avatar
Remmy Remmy is offline
OC3D Elite
I don't know if green LEDs would show up much against the coolant in the waterblock, but it's worth a shot. LEDs are only cheap so there's not much to lose by trying it
I'd definitely go for white lighting over UV, but that's my preference.
__________________
  #22
Old 09-12-13, 12:36 AM
GregPalos GregPalos is offline
Member
I will probably buy white lighting then ! The coolant is clear and I've seen that Plexi supremacy with LEDS inside glow quite well. Hopefully the white won't bleach out the green LEDs in the waterblock.
Thanks dude for the advice!
Oh and also how did you do that block of text about your build below your comments?
  #23
Old 09-12-13, 12:43 AM
Remmy's Avatar
OC3D Elite
I just manually type it every time I post.
Hehe, just kidding It's called a signature. Go into your User CP, and on the left hand side, under Settings & Options there's a link called Edit Signature. You simply type and format your text in there, and save it. You can put a URL in to your rig page too.
If you want to change the name of the link to the URL, you type this
(url=www.google.com)Google(/url)
which shows the text Google, and is linked to the URL. Replace the () with [].
__________________
  #24
Old 09-12-13, 12:50 AM
NeverBackDown NeverBackDown is online now
AMD Enthusiast
I agree on the white leds. Not blinding bright ones just some subtle ones.
  #25
Old 09-12-13, 02:04 AM
Member
Any advice on brands? I'm scared it might be too bright?
  #26
Old 09-12-13, 02:27 AM
AMD Enthusiast
Bitfenix and NZXT both have solid choices, i belive Phoybia have a multicolored led strip if that suits you as well.
  #27
Old 09-12-13, 06:04 AM
Remmy's Avatar
OC3D Elite
NZXT LEDs have three brightness settings on them other brands may as well, but I know for sure with NZXT
__________________
Tags
900d, christmas, marmite, watercooled
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
