Thread Tools Display Modes
  #281
Old 21-09-13, 11:46 AM
imersa's Avatar
imersa imersa is offline
Member
Awesome attention to detail. Following
  #282
Old 22-09-13, 01:08 AM
alpenwasser's Avatar
alpenwasser alpenwasser is offline
OC3D Elite
Quick and Messy Update
Thanks mate, I appreciate the support!
Quick Status Shots
Somebody on LTT requested some current status shots. It's not pretty and mostly disassembled, but since I've shot and
uploaded the pics I thought I might as well post them here, too. Yes, things are slightly messy ATM.
(click image for full res)
I'm currently painting the fans. Should have an update on that either Sunday or Monday, if all goes to plan.
  #283
Old 23-09-13, 02:47 AM
OC3D Elite
The Bitfenix Spectre Pro Copper Edition
I'll let the pictures do the talking for the most part.
I hung the frames on a thread (still had to rearrange them to cover all the angles).
The masking took about two and a half hours for all fans...
...because I had the genius idea to paint them both front and back, even though
nobody will ever see the back side again, ever. But the perfectionist inside me
just wouldn't shut up. You can also see that I desoldered the wires. Considering
how close together the contacts are on the PCB that's going to be a bitch to solder
back on. Ah well...
First coat of copper paint applied. The paint I'm using is Weicon Copper Spray.
The copper colour comes from actual copper particles (so, it's a metal spray, not
just something that looks like copper). The upside: It's copper! The downside:
It's conductive (most likely, I don't have a multimeter to test this, but I doubt
the epoxy matrix in which the copper particles are embedded serves as a good
enough insulator to make it non-conductive).
I found the paint on eBay, if you google "Weicon copper paint" you should be able
to find more info on it.
Aaand we're done. To be perfectly honest, the paint job could be improved upon.
But considering I don't have a spray booth and practically all imperfections are
well hidden when they're mounted I'm still very happy with the results. I'll
definitely change my procedure though if I ever do this again. It's a learning
process.
Also, to prevent the paint from tarnishing, I gave all the painted parts a clear
coat for protection.
And now, some glory shots:
Well, at least the masking did its job.
I also painted the hex bolts for mounting the fans. They also have a clear coat.
That's it for today. Next: Re-wiring the fans.
  #284
Old 23-09-13, 03:21 AM
Bartacus Bartacus is offline
OC3D Elite
My god, those look simply brilliant! Me wanty!
__________________
Guts: ThreadRipper 2950X / GB Aorus Xtreme X399 / 64GB TridentZ Royal 3600CL16 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU
Storage: 6TB RAID0 NVME array (ADATA SX8200 Pro 2TB x 3)
Water Cooling: HeatKiller TR4-Pro CPU block / HeatKiller IV GPU blocks / 360mm Darskide LP360 rads x 3 / Heatkiller reservoir
  #285
Old 23-09-13, 04:55 AM
mehere's Avatar
mehere mehere is offline
OC3D Crew
now they look the dog danglers nice one mate I dont envy you with the resoldering job
__________________
build log
  #286
Old 23-09-13, 10:10 AM
OC3D Elite
Thanks mate!
Yeah, I'm not necessarily looking forward to that.
  #287
Old 23-09-13, 11:30 AM
WillSK's Avatar
WillSK WillSK is offline
OC3D Elite
Send a message via Skype™ to WillSK
Those fans look the S**t!! Gorgeous mate
__________________
My Rig : Fractal S2 Case, ASUS Crosshair VIII Hero, Ryzen 3800X, Corsair H115i Platinum, MSI GeForce RTX 2080 GAMING X TRIO, 32 Gb Team Pro Dark RAM 3200Mhz, Samsung 970 EVO SSD, Samsung 850 Pro 500GB SSD, Seasonic Prime Ultra Titanium
  #288
Old 23-09-13, 12:11 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
Holy fuuuu-gulp-
That's sexy mate!
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #289
Old 23-09-13, 02:29 PM
Cxizent's Avatar
Cxizent Cxizent is offline
Newbie
Mate, seriously? Holy ! Could you, like, maybe tone it down a bit? You're really making the rest of us look bad.
  #290
Old 23-09-13, 03:17 PM
Tripp's Avatar
Tripp Tripp is offline
too many shrooms
bitfenix would do well if they made these haha, looking good mate keep the updates coming
Tags
560 radiator, caselabs smh10, copper, evga sr-2, geforce titan
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
