Thread Tools Display Modes
  #271
Old 16-09-13, 11:02 AM
alpenwasser's Avatar
alpenwasser alpenwasser is offline
OC3D Elite
Originally Posted by MrKambo View Post
love them fans
Hehe, yeah, me too
Originally Posted by Mark3Max View Post
WOW , the detail in this rig is going to be eye popping.
Great job again , the blocks look so much better with copper painted screws.
I'm not sure why they didn't put copper screws in them from the factory.
Thanks mate! Yeah having it come stock with copper screws really would have made more
sense. Ah well, this way I at least get to do some modding
  #272
Old 16-09-13, 11:23 AM
SeekaX SeekaX is offline
OC3D Elite
Originally Posted by alpenwasser View Post
Hehe, I still have an old Lian Li PC-343B. Although IIRC you're rather tall, so that
might be a little tight...
195cm, but i guess a little bit of origami will do.
  #273
Old 16-09-13, 11:37 AM
Cru's Avatar
Cru Cru is offline
OC3D Elite
pretty sure we can both fit in there... i'd like to move as well
  #274
Old 16-09-13, 03:02 PM
OC3D Elite
Origami masterclass
  #275
Old 16-09-13, 09:34 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Lovin your copper styling on the fans & blocks giving me some ideas for a future build.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #276
Old 16-09-13, 09:42 PM
FTR.4500MHz's Avatar
FTR.4500MHz FTR.4500MHz is offline
OC3D Elite
Lawlz, 2 German dudes in a lian li... Epic !
Is this the way you will wake them up Alpenwasser ?
Nice progress on your modding by the way !
__________________
Hardware: Shinobi XL w.custom window | Msi Z77A-GD65 | i5 3570k | 8GB Corsair Vengeance 1600MHz | 7970 Lightning BE | AX 850 | SSD's: Samsung 830 128GB , Corsair Force GT 120 GB | HDD: Seagate Barracuda 750 GB | XonarD2X | Edifier S730 | iiyama prolite g2773hs-gb1 |
Watercooling: EK supremacy p/n | EK 7970Ltg. a/n | D5+EK Top | UT60 360 and 240 rads | EK X3 150 res. | Tygon 13/19mm | Bitspower C.fittings |
  #277
Old 16-09-13, 09:47 PM
OC3D Elite
Thanks mate. Inspiring others is the best compliment one can get IMO.
<moepsehorn>
I love Scrubs!
I really wish we had rep/like/thumbs up on this forum.
In any case, I don't know how to play the Alphorn, but hey, I might learn just for the sake
of this (you know, for the cause ).
  #278
Old 18-09-13, 12:58 PM
Gk1ngs Gk1ngs is offline
Newbie
Loving the fans, they look so good you would think they were actually from the factory. Though stuff from the factor doesn't always look as good as your stuff. The copper screws is also a huge improvement for the blocks. Your build is just gonna be epic when its complete.
  #279
Old 18-09-13, 07:10 PM
OC3D Elite
Thanks for the kind words mate!
I have taken all the remaining fans apart and will be masking and painting them some time this
week.
  #280
Old 20-09-13, 10:04 PM
OC3D Elite
Fan Disassembly
Fan Disassembly
I actually wanted to make a video of this, but I didn't have the time to do it properly,
and I'd rather do it not at all than sub-par. It would have been easier to follow along
if somebody else wanted to take their fan apart, but for the time being still pics will
have to do.
Side note: This post is more geared towards those who've never taken a fan apart.
For most other people it will probably be rather boring and trivial.
(click image for full res)
First, take the inner frame out of the outer one. I have found it is easiest to do this
by pressing on the inner frame between the two lugs in each corner instead of the
lugs directly.
Next, take off the sticker on the back. I use some petroleum ether to get rid of the
sticky residue (very annoying stuff).
Then take out the gasket which covers the bearing's back side. It's not extremely
delicate, but if you're not careful you can damage it nonetheless. Also, you can see
my most important tool for this process: A dental tool.
And here comes the part which is actually tricky. The rotor is held in place by a small
washer which sits in a groove on the rotor's axis. The washer has a slit in it.
I found the easiest way to get this washer out of that groove to be this:
  • Take two of those dental tools from above.
  • Press down on the washer with one of them and make sure it doesn't rotate
    anymore (remember: this is a bearing made for rotation, so it moves rather
    easily and is well lubricated, i.e. slippery).
  • Press the tip of the second dental tool into the slit of the washer and twist
    one of the ends of the washer upwards (this usually takes me several tries since
    I often slip). The washer is very flexible, so don't worry too much about breaking
    it. Be careful, but not afraid.
  • Once the washer is nicely twisted and one of its ends pointing out of the
    bearing, get the second dental tool under the washer and pop it out.
  • That's it, you can now slide the rotor out on the other side.
The washer is the white thing inside the red circle.
The red arrow is pointing towards the washer's slit into which you need to get the
tool.
And here we have the bearing with the rotor removed. The red ring is actually an O-ring
resting on top of another washer. Both of these are actually loose and are only held in
place because the lubricant makes them a bit sticky (you will have noticed this when
taking out the washer in the above step). There is also one of these O-rings on the
rotor axis itself. You can take them out if you want, but I left them in.
The disassembled rotor and inner frame:
And my disassembled army of fans (you know, the other one ):
I don't think you necessarily need dental tools to do this, but I had them anyway,
tried them out and found them to work very well for this. If you want to buy some,
you can get them on eBay for a few bucks per set.
I'm currently painting the fans and should have an update on that some time over
the weekend.
That's it for today. Thanks for stopping by,
-aw
Tags
560 radiator, caselabs smh10, copper, evga sr-2, geforce titan
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
