Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat > Serious Discussion
  #31
Old 12-10-14, 08:09 PM
DJundertaker25 DJundertaker25 is offline
Newbie
I've been playing without my vid card to see whether that fixes it. And it doesn't the crashing isn't caused by my videocard apparently. So i'm thinking maybe the mobo or cpu have a defect. But i don't really have a way of testing which one is broken.
__________________
i5 3570k (@4.5 ghz)| sapphire r9 290 tri-x (@1200mhz and 1400mhz memory))| 8gb g. skill @2133mhz | Corsair H110 (with 2* Bifenix Spectre LED 140mm) | Corsair Obsidian 750D | MSI z77a-g43 Gaming | Corsair RM850 | Samsung Seagate ST1000LM024 (1Tb) | Razer Blackwidow Ultimate BF4 edition | Speedlink Decus Gaming Mouse | Roccat Kave 5.1 XTD |
  #32
Old 12-10-14, 09:53 PM
paulstung's Avatar
paulstung paulstung is offline
OC3D Elite
You need to go into event viewer mate and get the error code, click start type in event viewer, and go through the times of the crashes to get the logs.
I couldn't figure out my odd issue, so I went over onto the Windows 8 forum, the guy solved it within hours, you might want to try there, they have a section for BSOD's and the guy is a god send mate, he is there resident expert, he is on the 7 and 8 forum. There is a step by step guide on how to post your dump files from the event logs, follow those steps and he'll get back to you, with a full break down and what to do.
Here's the BSOD page link
http://www.sevenforums.com/bsod-help...tructions.html
Here's the link on posting instructions for the 7 forum.
  #33
Old 15-01-15, 09:44 AM
Newbie
After a long time i've finally figured it out, it turns out that the sevenforums guru wasn't able to help though. The crashes were caused by general hardware problems. After i had concluded which component it was (turned out to be my mobo) i send it back and they send me a new one, everything works fine now no crashes whatsoever.
Thanks for all the help and support
__________________
Tags
crashes, i5-3570k, z77-g43_gaming
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
