Go Back   OC3D Forums > [OC3D] Hardware & Software > Sound Cards & Speakers
Thread Tools Display Modes
  #1
Old 13-03-15, 01:26 PM
Bar Bar is offline
Newbie
headphones recommendation and one more thing
hey guys,i need you to help me choose headphones/set and about 150~200$
also i would like you to help me get them to work with my PS3 and PS4 aswell as my PC.
  #2
Old 13-03-15, 01:37 PM
MadMarc's Avatar
MadMarc MadMarc is offline
OC3D Crew
Quite a few of the guys here use Beyerdynamic headphones, so I'd check out the Custom One Pros or the DT 770 Pros both have/are available with a low impedance, so you don't need any fancy audio equipment to drive them.
As far as I know the PS3 only has an optical audio out (no idea about the PS4), so you'd need a separate amp/dac unit to use them on the consoles
__________________
  #3
Old 13-03-15, 01:59 PM
Bar Bar is offline
Newbie
i was looking at the astro mixamp for that but i really dont know.
anyway thank you for your help i will look into these headphones.
may i ask what the general opinion about audio technica ad400/500/600?
  #4
Old 13-03-15, 05:27 PM
Bar Bar is offline
Newbie
guys any other recommendation?
  #5
Old 13-03-15, 06:37 PM
AMD Enthusiast
Not many are confirmed to work with the PS4 yet so its difficult to help. AFAIK the HyperX Cloud Gaming headset should work. Also happens to be cheap but amazing for the money
  #6
Old 26-02-19, 10:32 AM
MacLeod's Avatar
MacLeod MacLeod is offline
OC3D Elite
I can vouch for this. I've been running the Cloud Alpha for a while now and it sounds great. I like them better than my Sennheiser HD558's I had forever, and I loved those! The mic sounds great too.
They usually run $100 and I'd be willing to bet there aren't a lot of cans out there cost twice as much that could be the HyperX by much.
  #7
Old 26-02-19, 10:56 AM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
A 4 year thread necro, This must be some type of record
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #8
Old 26-02-19, 03:12 PM
AlienALX's Avatar
AlienALX AlienALX is online now
OC3D Elite
Originally Posted by Warchild View Post
Please check the date on a post before you reply.
It looks like spam to me.
__________________
  #9
Old 26-02-19, 10:00 PM
MacLeod's Avatar
OC3D Elite
Yikes! I didn't even notice, it showed up on my New Posts feed. I never look at the dates anyway cause I can't read those British dates... Is it month first or year first then day or day first then month...
No wonder y'all drive on the wrong side of the road
  #10
Old 27-02-19, 07:36 AM
Warchild Warchild is offline
OC3D Elite
Its not British dates, its 90% global. Its only America that does MM DD YY
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
