Go Back   OC3D Forums > [OC3D] Customer Care Forums > Asus UK Customer Care Forums
  #1
Old 18-05-20, 10:05 PM
steverebo's Avatar
steverebo steverebo is offline
OC3D Elite
RTX 2080ti strix screws and thermal pads
so I've managed to lose the screws and thermal pads for my sons RTX 2080to strix gpu after watercooling it and now he has swapped to a new case and wants the stock cooler back.
Am I able to source a new screw set and some thermal pads direct from asus or am I stuffed?
__________________
BeQuiet Darkbase Pro 900 | i7-7700K OC @ 5.10GHz | Custom water loop | ASUS MAximus Hero IX Z270 | Aurous Xtreme GTX 1080TI @ 2120mhz 12000mhz | 16GB Corsair Dominator Platinum @ 3200MHz CL15 | 500GB Samsung 960 Evo, 250GB Samsung EVO 850 | Corsair HX750I PSU | Windows 10 Pro 64-bit
  #2
Old 18-05-20, 10:53 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
The thermal pads are easy to find, if you know what thickness they are.
The screws? it depends what they used. I doubt Asus will sell you anything like that. They're not known for being very approachable. Good luck though.
__________________
If you don't like what I post don't read it.
  #3
Old 18-05-20, 11:05 PM
WYP's Avatar
WYP WYP is offline
News Guru
Hmm, is there a way that you can figure out the thread size of those screws? You might be able to purchase some online if you can find that out.
Just a tip for the future, screw your screws into the heatsink when you are storing it, stick the thermal pads onto it and then wrap the heatsink in cling film or something. That's what I do when I watercool.
  #4
Old 18-05-20, 11:11 PM
AlienALX's Avatar
OC3D Elite
If the screws can go back I do that. If not I just put them in a seal up baggie and masking tape it to the cooler.
__________________
  #5
Old 19-05-20, 05:28 AM
steverebo's Avatar
OC3D Elite
Didn't think of screwing them into the cooler I just put them into a baggie with the thermal pads and put them in the box with the cooler. They went walkies at some point no idea how.
Hmmmm I was hoping Asus might be able to send me a set of screws the thermal pads don't really worry me as I can source them easily enough
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
