Go Back   OC3D Forums > [OC3D] Customer Care Forums > Asus UK Customer Care Forums
  #1
Old 10-05-20, 11:21 PM
SparkleDJackson's Avatar
SparkleDJackson SparkleDJackson is offline
OC3D Elite
rampage v edition 10 usb issues
turns out my keyboard is fecked as its doing the same disconnecty thing.
__________________
6900k, Evga RTX 2080 ti watercooled w/backplate
64GB Corsair Dominator Platinum 3200, Rampage V Edition 10
Corsair 900D.
  #2
Old 11-05-20, 05:12 AM
looz's Avatar
looz looz is offline
OC3D Elite
The way you describe it sounds indeed like a hardware issue, but I'd try installing drivers just in case windows update installed a broken revision or something similar.
https://www.asus.com/fi/Motherboards...Desk_Download/ there's a USB driver further down.
But in case it's the controller, USB 3.0 PCI-E cards are a decent option, though if you still have 780 SC SLI, it's possibly going to be a compromise in PCI-E lanes and GPU airflow... For example: https://www.amazon.co.uk/FebSmart-Se...dp/B07MZ3Q5KQ/
You could also try splitting the USB-C ports, but might be the same controller, I am not sure on that. Maybe your phone came with a USB-C to USB adapter so you could try out its function.
__________________
i7 9900k - 16GB - 3080 XC3 Ultra - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
