Go Back   OC3D Forums > [OC3D] Forum Teams > Redline Folding @ OC3D - 98860
Thread Tools Display Modes
  #1721
Old 21-01-20, 03:21 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
Another folder across the 1 billion points mark! Congrats SOA_RRU!
__________________
CaseLabs Mercury S3 | AMD 3900X | ROG CH8 Impact | RTX 2080 Super | 32GB DDR4 | 1TB NVMe
Acer Predator Z35P
  #1722
Old 22-01-20, 12:16 AM
riotcity76 riotcity76 is offline
OC3D Crew
Dang, he's right on my tail! Congrats SOA_RRU!!!
__________________
  #1723
Old 26-01-20, 08:02 PM
stevehat1 stevehat1 is offline
98860 #1 Folder
Nicely done, congrats on one billion!!
__________________
Folding since 1 WU=1 point.
Proud to represent OC3D on the 1st page of all Folding @ Home donors
  #1724
Old 27-01-20, 04:20 PM
SOA_RRU's Avatar
SOA_RRU SOA_RRU is offline
Advanced Member
Thanks guys
Need to dump my 1070 and get another 2060 Super or better as i want 3rd place back
__________________
RTX 2060 Super / GTX 1080 / GTX 1070 DEAD (AGAIN)
  #1725
Old 27-01-20, 04:34 PM
trawetSluaP's Avatar
trawetSluaP trawetSluaP is offline
OC3D Crew
Tempted to get back into Folding. Thought it was causing an issue with my PC but turns out it was something different so may start again.
__________________
Enthoo Elite | i9-7900X | Rampage VI Extreme | Dominator Platinum 32GB | RTX 2080 FE | 960 Pro 512GB, 840 Evo 250GB x 2 | EVGA SuperNOVA 1200 P2 | S2721DGF, MX27AQ | Custom Watercooling Loop + Aquaero 6 XT
  #1726
Old 27-01-20, 05:30 PM
hmmblah's Avatar
Moderator
It'd be great to have you back....no pressure!
__________________
Acer Predator Z35P
  #1727
Old 31-01-20, 07:56 PM
OC3D Crew
Originally Posted by SOA_RRU View Post
Thanks guys
You'll get it soon enough as I have no plans on upgrading any time soon.
Although, I may feel differently once I've been bumped down to 4th. I hear it's dusty and moldy down there.
We'd love to have ya back
__________________
  #1728
Old 02-02-20, 03:08 AM
98860 #1 Folder
Thanks guys
How has the 260 super been working for you PPD wise?
270 super of mine has seen 2.25 mil PPD on one of the core 22 projects. Normally runs 1.3 to 1.9+ mil on other projects. Might get one more good card before retiring from this nonsense. But before that happens i'll need to get a good wireless router that will work reliably downstairs.
Anybody have any recommendations that will work well on a quite large two story home??
__________________
  #1729
Old 02-02-20, 05:34 PM
SOA_RRU's Avatar
Advanced Member
Originally Posted by stevehat1 View Post
How has the 2060 super been working for you PPD wise?
2070 super of mine has seen 2.25 mil PPD on one of the core 22 projects. Normally runs 1.3 to 1.9+ mil on other projects. Might get one more good card before retiring from this nonsense. But before that happens i'll need to get a good wireless router that will work reliably downstairs.
Lowest i've seen is just over 1mill and highs of just over 1.9mil.
I'd like to try a EVGA 2060 KO just to see if using the TU-104 (2080 & 2070S) makes much of a difference whilst folding. From the reviews i've seen the gaming performance is stock 2060 BUT the workstation performance is upto 47% faster.
I've seen the odd 2060 KO numbers floating around and they were like 1.3mill but what one person gets it doesnt always follow suit that someone else will get the same results using the same equipment + the massive variations between current core 21 & 22 wu's ppd makes my head spin.
Price wise the KO is around £50-75 cheaper than the cheapest 2060 Super so might be worth the gamble?
P.S Not all 2060 KO's use the TU-104?
__________________
  #1730
Old 03-02-20, 11:45 PM
OC3D Crew
Right, so I'm back at it, but... Two questions.
1) I have a global frame cap in NC enabled, am I right in thinking this won't affect Folding?
2) My GPU Memory is OC'd to 8024, however, with some work units Afterburner reports Memory speed to be 7824. Is that normal?
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
