  #31
Old 02-01-18, 09:19 PM
AllyB AllyB is offline
Newbie
Originally Posted by WYP View Post
TBH a GTX 1080 Ti is crazy overkill for a 1080p display. I'd say a 1080 Ti is worth it if you want to upgrade to a 1440p monitor, but if you are sticking to 1080p a 1070Ti GPU might be a better option, as 1080p will leave a lot of performance on the table a lot of the time.
Yeh i did just wonder about it tbh, i will eventually look at upgrading to a 1440p monitor but it will be later this year/next year or knowing me i'll never get round to it lol
  #32
Old 02-01-18, 09:24 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
DSR to 1440p and beyond
__________________
If you don't like what I post don't read it.
  #33
Old 02-01-18, 09:28 PM
Newbie
This is true, or hook it up to my 4K telly downstairs
  #34
Old 02-01-18, 09:51 PM
AlienALX's Avatar
OC3D Elite
Yup, then use Fastsync.
__________________
  #35
Old 02-01-18, 10:13 PM
Korreborg's Avatar
Korreborg Korreborg is offline
OC3D Crew
I would get a 1080ti, a 1440p G-sync monitor and an extra 8GB of DDR3.
Then wait 2-6 months to see what Ryzen+ turns out to be and whether the DDR4 prices go down.
__________________
[I9-7900X][Asus Strix X299-E][EVGA 1080TI FE][Corsair 16GB 3733MHz][Fractal Meshify C][Corsair AX860i]
[Samsung 970evo 500GB+1000GB of mixed SATA SDD's][ASUS PG278QR][Logitech G510s and G502][Steelseries Wireless H]
  #36
Old 02-01-18, 10:17 PM
Newbie
Thats blowing the budget a little bit getting the monitor lol. Think the build i'm looking at getting so far works well, only other thing i've considered is maybe one of the cheaper 1080ti, but then obviously suffers on clock speed.
  #37
Old 02-01-18, 10:32 PM
Korreborg's Avatar
OC3D Crew
The thing is. Go up in resolution and the GPU gets hammered = The CPU isn't as important.
OC that i5, and you can easily game for another year or more.
As you can see, i have a i7 4790k, i upgraded from a 4670k 9 months ago, didn't really gain a ton of FPS. And 1440p Ultra setting just looks stunning. Going from 24" 1080p to 27" 1440p is the best gaming thing i have done in a LONG time
__________________
  #38
Old 02-01-18, 10:37 PM
Newbie
Just watched the figures part, yeh i get what your saying, i have noticed that my CPU does struggle abit with some of the games i play, mainly warhammer 2 and some of my more CPU intensive games, hence why i'm thinking bugger it i may aswell just upgrade the lot while i'm at it.
  #39
Old 03-01-18, 10:55 AM
Korreborg's Avatar
OC3D Crew
With a G-sync monitor i don't think you will notice a difference
As i see it, as long as its not a competitive game 60 or 100 fps isn't important.
__________________
  #40
Old 03-01-18, 12:09 PM
AlienALX's Avatar
OC3D Elite
Nope. And any way, Fast Sync will run the game as fast as you can run it any way.
I was going to do a big write up on this but to cut it all very short.. Adaptive Vysnc globally cures any tearing and input lag. The price? you *will* feel the game slow down and it will be noticeable but you won't get any tearing or input lag. I have not used Fast Sync yet. I have, however, used Gsync and it wasn't that much better than AVS. Again, you *will* most certainly notice the game slowing down. Absolutely 100% it's unavoidable when you tank from 80 to 30 FPS for example, but it seems to do a similar thing to AVS where you don't get any tears or input lag.
The answer for perfection? as always, throw power at it. *if* you can keep your min FPS above 60 on a 60mhz monitor Vsync will be enabled but there will be no input lag. It really is as simple as that.
There are two main bugbears with gaming. Tearing and lag. Tearing is hideous (it happens when your FPS exceed the hz of your monitor) and lag causes death. In BF3 I could not do the sniper in the mall part because of input lag. It was awful. However, like I said, no technology no matter how good is going to stop the sensation of dropping from 80-30 FPS, or in fact any 50% drop in frame rate. You are definitely going to feel it and notice it, no matter how good the technology for preventing tearing and input lag. That is just PC gaming.
I just throw Titans at the resolution I run. It has worked very well for me. Much better than Gsync, which I did have.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
