  #11
Old 21-02-17, 09:07 PM
SaaintJimmy SaaintJimmy is offline
Member
Originally Posted by NoobCase View Post
So much detail... Really like where this is going!
Those 45 bends you have on the GPU runs..? Are those kinked or just the pictures and gpu heatsink thingy messing with me?
The longer one is actually a bit squished, because I don't really like how the Alphacool silicon guide works (a little too small). I'll try to redo it but I think it will be totally invisible once filled!
  #12
Old 22-02-17, 11:54 AM
NoobCase NoobCase is offline
Member
what tubing are you using? 12mm OD? Brand? You could try ordering the silicon insert from EK or one of the other manufactures to see if those have a better fit.
  #13
Old 22-02-17, 03:31 PM
Member
These are 16/13, I normally use the EK guide for 12mm ID and it works just fine, even with Alphacool tubes. I requested 16/12 tubes to Aquatuning and they sent me 16/13 by mistake. I don't bother, next time I'll just use 16/12
  #14
Old 09-03-17, 11:00 AM
Member
Little update guys! More to come next week
  #15
Old 09-03-17, 08:11 PM
Skeeper Skeeper is offline
Newbie
Definitely better suited insert thicker than the one that has clearances inside the tube in.
Many persons have problems with this.
Personally for tubes with an inner diameter of 13mm, I use an insert with a diameter of 14mm.
For pipes with an inner diameter of 8mm, I use an insert with a diameter of 8,8mm.
I understand that you will not be corrected, these tubes - leave as is?
  #16
Old 10-03-17, 12:28 PM
Member
Sorry but I didn't understand your question
How do you manage to fit a 14mm insert in a 13mm tube? It's like putting an M4 screw in an M3 hole that must be a pain to remove it once the bend is done!
Anyway, what brand are your inserts?
  #17
Old 10-03-17, 08:46 PM
Newbie
Thus I formulate the question differently - if the you corrected these tubes?
(bending of them, flattened arches, uneven arches, etc.)? - CLICK
Application to insert 14mm narrower tube is possible.
I do it only on a straight stretch.
If you are already a bow, it still does not make sense to carry out the insert by it - but - the condition is to do it properly.
  #18
Old 14-03-17, 06:11 PM
Member
The bends on the frosted tubes are correct, the light could make them look weird but they're ok!
What brand your 14mm insert is?
  #19
Old 14-03-17, 09:39 PM
Newbie
OK, I understand, and thank you for your reply.
I'm sorry too, that previously have not written about the company insert.
Insert is not a brand - it comes from a company producing semi-finished plastics, silicones, rubber and other materials that I use in my work..
  #20
Old 14-03-17, 10:42 PM
Member
Uhmm, I might look for something like that too! Because in the end it's just silicon, it's not something very specific
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
