Go Back   OC3D Forums > [OC3D] Processors & Platforms > Memory
  #1
Old 20-04-16, 03:54 PM
steverebo's Avatar
steverebo steverebo is offline
OC3D Elite
Corsair lpx vs dominator platinum dr4
Other than looks spec for spec what is the difference between the lpx and dominator ddr4 range?
__________________
BeQuiet Darkbase Pro 900 | i7-7700K OC @ 5.10GHz | Custom water loop | ASUS MAximus Hero IX Z270 | Aurous Xtreme GTX 1080TI @ 2120mhz 12000mhz | 16GB Corsair Dominator Platinum @ 3200MHz CL15 | 500GB Samsung 960 Evo, 250GB Samsung EVO 850 | Corsair HX750I PSU | Windows 10 Pro 64-bit
  #2
Old 20-04-16, 03:56 PM
TPC's Avatar
TPC TPC is offline
OC3D Elite
nuffink. The Doms sometimes have tighter timing, which you could achieve with the LPX too... But marketing bla bla let's not go there. Technicly there is no difference between the cheapest ram ever or the most expensive. (apart from timing and freq)
  #3
Old 20-04-16, 04:04 PM
steverebo's Avatar
OC3D Elite
Cheers was contemplating swapping my lpx 3000 for a set of dominator platinum 3200 but I think I will leave it alone then
I thought they might have been pre binned IC's or something unique, never mind
__________________
  #4
Old 20-04-16, 04:09 PM
JR23 JR23 is offline
OC3D Elite
Some are genuinely better IC's like G.Skill or TeamGroup's uber fast kits, not exactly worth it for daily ambient usage but what they can achieve is crazy.
I do not think the gains will justify the price difference, except maybe in the aesthetics department but Dominator Platinums aren't as shiny as they used to be .
JR
  #5
Old 20-04-16, 04:13 PM
TPC's Avatar
TPC TPC is offline
OC3D Elite
JR
Just from the standpoint of functionality a noname Ching Chong Lu Fu Ram will do the same thing like the Dom Plat or whatever. As long as you compare similar speeds etc.
Of course there are some specialties like Crucial that sometimes provide software with their ram to check temps or change lighting but there is no real benefit in that and is just a nice gag.
  #6
Old 20-04-16, 05:00 PM
steverebo's Avatar
OC3D Elite
Cheers guys, I do like the look of the dom plats but if it's purely cosmetic I can't really justify the xtra cost
__________________
  #7
Old 21-04-16, 02:40 AM
Kaapstad's Avatar
Kaapstad Kaapstad is offline
OC3D Elite
For the normal dom plats it is not worth the extra as it is just cosmetic.
For extreme situations and memory speeds/timings the Dominator Platinums are worth it for things like benching but they will do nothing for normal use like gaming.
__________________
OC3D Overclockers Club Member
#041
GTX 960 owner and proud of it.
  #8
Old 21-04-16, 06:56 AM
Warchild Warchild is offline
OC3D Elite
I find the Dominators have lost their good looks now. They just seem so common. I really want to get a set of KLevv sticks. By far the best looking ones out there right now.
But without sidetracking. Stick with the LPX
  #9
Old 21-04-16, 08:20 AM
steverebo's Avatar
OC3D Elite
Cheers guys, I must say I do like the klevv memory I remember when they showcased Thier ddr3 modules are some looked amazing
__________________
  #10
Old 21-04-16, 12:53 PM
OC3D Elite
I dont like all their designs. but the genuine series are sexy.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
