Go Back   OC3D Forums > [OC3D] Project Logs & Gallery > Rig Gallery
  #1
Old 15-04-14, 05:24 PM
paulstung's Avatar
paulstung paulstung is offline
OC3D Elite
Black hole sun
So after a nightmare or a time with my hose and coolant reacting, turning the sunset yellow into, first pee of the morning orange, I decided to strip the loop,flush and re-do it all. Doing so I actually got to use my Pexon cable set.
I'm not overly happy with the runs, but, I'm changing the fittings in a week or 2, so I didn't go through my usual sit back and look, for a while, I just jumped straight in, and got it done. I'm sick of it being down from one thing or another, and I really want to get more than a weeks use in between down times. Plus I've just bought Titanfal and am itching to get started.
Intel i5 4670k @ 4.2, on 1.015v
MSI Z87 MPower
2 x HD 7950 in Crosfire
16gb 1866 Avexir Core
120gh Kingston HyperX ssd Steam
120gb Kingston HyperX ssd Origin
180gb Intel 530 ssd boot
256gb Samsung ssd all other stuff
RM 750w with custom cables from Pexon
Cooling
XSPC Raystorm cpu block
2 x Alphacool NexXxos gpu blocks, and back plates.
Monsta 480 / Monsta 460
Akasa Vipers 120mm / 140mm all round in push pull
Koolance PMP500
XSPC Photon 270
Primochill flow sensor
Masterclear 7/16 hose
1/2 Fesser barbs / Fesser rotaries
mayhems pastel yellow / Mayhems X1 yellow
All inside a Phanteks Enthoo Primo
3 x AOC I2396vm monitors in Eyefinity
RAT 5 mouse
Stealseries Merc Srealth keyboard
Microlab Solo 7c's active monitor speakers
  #2
Old 15-04-14, 05:27 PM
tinytomlogan's Avatar
The Guvnor
Please add specs matey - there is a sticky on how to post in here
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #3
Old 15-04-14, 05:44 PM
Josh Weston Josh Weston is offline
OC3D Elite
Ohai.
  #4
Old 15-04-14, 05:58 PM
KING_OF_SAND KING_OF_SAND is offline
OC3D Elite
Looks like Orange Juice
  #5
Old 15-04-14, 06:30 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
When did Razer start making a rat5 mouse from Saitek ???
__________________
= Steam/Origin/Uplay - Dicehunter =
  #6
Old 15-04-14, 07:20 PM
paulstung's Avatar
OC3D Elite
Early 2011 I think mate. good spot
  #7
Old 15-04-14, 08:32 PM
Mysterae's Avatar
Mysterae Mysterae is offline
OC3D Crew
Nice looking rig mate, especially the feature of the SSDs!
Was it because of aesthetics that you decided to put the gpu's in parallel? You could have gone serial easily with the small benefits it brings, plus I think it would look a bit better with less fittings to worry about .
Did you sort yourself out LEDs for the Raystorm?
  #8
Old 15-04-14, 09:11 PM
paulstung's Avatar
OC3D Elite
Cheers mate, the parallel over serial is mainly for the looks mate, I've had it running both ways, with no noticeable difference, either way.
yea I went with basic white led's and swapped the black ally surround out for the standard plexi version. Something didn't sit right with the black on the block, it just doesn't look right unless it's lit up. I did order 2 twins but one of the led's shattered as soon as I put it in the block, the hole wasn't quite finished, but a quick poke with a blade soon sorted it.
I've ordered a 10 mtr, roll of 5050 rgb smd's, along with a sound activated controller, with the plan to have around my desk and monitors, as well as inside the case, reactive to game sounds, as well as movies and music. I've been using the NZXT braided strip lights for a while, but they don't cut the mustard any more. So I don't see the point in putting them in to remove as soon as the new strip comes.
  #9
Old 15-04-14, 09:36 PM
Mysterae's Avatar
OC3D Crew
10 metres? That should do you! Last year I built a "floating wall" in the living room using the LED strips behind it. You'll be surprised how much they light the room - for example from settings 1 to 10 the setting used normally is 3.
I digress. Did you think of yellow LEDs for the Raystorm? That would go so well in your build. If I had any yellow LEDs (I've only got white and UV) I'd build you a circuit that you can connect to the Aquaero and dim it accordingly (still using it yeah?). You can buy 50x 3mm yellow 20mA LEDs from ebay £3.68 delivered.
  #10
Old 15-04-14, 11:20 PM
paulstung's Avatar
OC3D Elite
I haven't been able to find any true yellow as of yet, i've bought quite a few, and they all turn out to be amber. If I was going tom keep my ram, I wouldn't mind so much, but the amber light is doing my head now.
Cheers for the offer mate, It has made me remember I've got an Aquaero 5 lt in my shed, that I forgot all about. So no as of now, I'm not using it, I've got my top rad controlled by the motherboard, and the bottom one on 7v, so the top is running passively for about 75% of the time, and comes on at 50 degrees. If it works the way I've set it up to, I shouldn't need to use the A5 lt.
.With the 10 mtrs I'm thinking of doing my hole wall, cos right next to my desk I've got my 50" tv, that is about to go up on the wall, so it might look pretty cool, as there isn't much room that isn't taken up buy tech, in one form or another. It should make a nice affect.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
