Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
  #1
Old 23-03-14, 08:13 AM
Damien c Damien c is offline
OC3D Elite
Nvidia's Next Driver To Give Mantle Type Gains
So Nvidia have a not yet released driver that they say will give similar performance gains to Mantle but these performances gains, are done in DirectX 11.
http://www.pcper.com/reviews/Graphic...y-Improvements
NVIDIA shows this another way by also including AMD Mantle. Using the StarSwarm demo, built specifically for Mantle evaluation, NVIDIA’s GTX 780 Ti with progressive driver releases sees a significant shift in relation to AMD. Let’s focus just on D3D11 results – the first AMD R9 290X score and then the successive NVIDIA results. Out the gate, the GTX 780 Ti is faster than the 290X even using the R331 driver. If you move forward to the R334 and the unreleased driver you see improvements of 57% pushing NVIDIA’s card much higher than the R9 290X using DX11.
If you include Mantle in the picture, it improves performance on the R9 290X by 87% - a HUGE amount! That result was able to push the StarSwarm performance past that of the GTX 780 Ti with the R331 and R334 drivers but isn’t enough to stay in front of the upcoming release.
Thief, the latest Mantle-based game release, shows a similar story; an advantage for AMD (using driver version 14.2) over the GTX 780 Ti with R331 and R334, but NVIDIA’s card taking the lead (albeit by a small percentage) with the upcoming driver.
Will be interesting to do some game tests and benchmarks tests.
__________________
Gaming PC: AMD 3950X, 32GB Corsiar DDR4, MSI 2080Ti, WD Black 1TB NVME
Server PC: 2700x, 16GB Corsair DDR4, MSI GTX 1660Ti, Gigabyte 120Gb M.2, Crucial 240Gb SSD, WD Blue 500Gb SSD, 2x Seagate 6Tb HDD's
  #2
Old 23-03-14, 11:13 AM
SieB's Avatar
SieB SieB is offline
OC3D Elite
This gonna be interesting
I love how PC gaming is finally getting the much needed advancments and optimizations to improve performance. Mantle, DX12, improved OGL, that other API some other group is working on and now this improvement with DX11. The next couple of years are going to see some good changes for all.
__________________
NZXT Switch 810 - Ryzeny 3600 - Gigabyte X570 Gaming - 32GB Corsair Platinum SE - MSI Gaming 1070 - Crucial MX100 256GB SSD - Crucial MX500 500GB SSD - Samsung F3 1TB HDD - Corsair H100 - Corsair RM1000i SE - Asus VE247H
PC Audio: Asus Xonar STX - Sennheiser HD650.
Portable Audio: FiiO X3II - Audiofly AF140 - Etymotic ER4s - Fidue A83.
  #3
Old 23-03-14, 11:24 AM
SeekaX SeekaX is offline
OC3D Elite
that would be quite impressive but i'll take that with a grain of salt.
i doubt it will keep up with mantle, DX11 has been around for quite some time, such performance increases usually don't happen at this point in time.
if they manage to do this AMD will look like morons.
  #4
Old 23-03-14, 12:31 PM
SuB's Avatar
SuB SuB is offline
The Webmaster
tbh if they manage to do this, nVidia will look like morons... why would it take this long to get that kind of performance gain from drivers? Doesn't this just show how much they've been slacking?
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #5
Old 23-03-14, 12:38 PM
iBeInspire iBeInspire is offline
OC3D Elite
The entire industry is constantly slacking... they make more money that way.
__________________
/|i5 4690k @4.6Ghz @1.315v /|\ Asus Z97-AR /|\ 8Gb G.Skill RipjawsX /|\ Asus GTX970 Strix |\
/|TX550m /|\ Samsung 840 Pro |\
/|Asus Essence STU /|\ Hifiman HE-400S /|\ AKG K551|\
[OFFICIAL] OC3D Overclockers Club Member [#025]
  #6
Old 23-03-14, 12:44 PM
SieB's Avatar
OC3D Elite
Either that or they have been holding back on purpose, it is a bit strange that after all this time they suddenly unlock performance in DX11. Plus if the improvements are within DX11 then I would of thought AMD could utilize the same improvements as well.
I doubt AMD, OGL and MS would create new APIs if it could all be done in DX11 though.
__________________
  #7
Old 23-03-14, 12:45 PM
SPS SPS is offline
Moderator
This is exactly what I was thinking...
  #8
Old 23-03-14, 01:07 PM
Vicey Vicey is offline
OC3D Crew
NVIDIA always over promise. I'll believe it when I see it. And this is coming from someone that has been using their products since the 6800GT a decade ago.
(6800GT, 7800GT, 8800GTX, GTX 260, GTX 480, GTX 780, all the desktop NVIDIA cards I've had).
__________________
Intel Core i9 7900X @ 4.7GHz [Delidded & Lapped] @ 1.23v Asus Rampage VI Extreme G.Skill Trident RGB 32GB 3600MHz CL17 Samsung 1TB 970 Pro NVIDIA GTX 1080 Ti FE @ 2GHz Asus Swift PG279Q Custom Water Loop
  #9
Old 23-03-14, 07:37 PM
OC3D Elite
i suppose both manufacturers will look like morons then.
and yes they have been slacking, what's the point of delivering something better if there is no need to deliver it.
  #10
Old 23-03-14, 07:51 PM
AMD Enthusiast
Starswarm is not even a good benchmark. Its far from consistent.
Plus Oxide have said they optimized DX11 far more than Mantle. So Nvidia really only just optimized for the benchmark.. not exactly for everything else.
All the benchmark is good for is seeing relative gains. Not as much for consistent repeatable scores.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
