Go Back   OC3D Forums > [OC3D] Forum Teams > [OC3D] Benchmark Team
Thread Tools Display Modes
  #11
Old 01-04-15, 09:57 AM
Warchild Warchild is offline
OC3D Elite
Originally Posted by MrKambo View Post
I've always wondered, do higher clock speeds on each card in SLI matter? Or do they all need to be the same?
I think its irrelevant. From what I gather, when in SLI, the cards will run at the speed of the slowest card.
  #12
Old 01-04-15, 10:13 AM
JR23 JR23 is offline
OC3D Elite
Not any more they all boost individually, you can overclock them individually or bind them together.
JR
  #13
Old 01-04-15, 10:18 AM
Kaapstad's Avatar
Kaapstad Kaapstad is offline
OC3D Elite
With 4 GPUs even if you set them to run the same when they boost they often end up running slightly different clockspeeds but normally within 13mhz of each other.
On a stock GTX 690 you also see this with the two cores boosting slightly differently.
Having said that my 4 TXs all seem to boost the same when working together, this is the first time I have seen this with 4 way SLI.
__________________
OC3D Overclockers Club Member
#041
GTX 960 owner and proud of it.
  #14
Old 01-04-15, 10:21 AM
OC3D Elite
JR
Interesting. So would it be better then to OC the cards together until you hit your maximum , then try to tweak each one individually to see which one of the two could go higher?
  #15
Old 01-04-15, 10:28 AM
OC3D Elite
Like Kaap said they all kind of reserve the right to do their own thing even when you do tie them together. On air my 780's always wanted to do something different to each other. But under water they seem to behave exactly the same, GPU boost 2.0 keeps its eye on a bunch of parameters and it won't hold back the array because one card is outside of the targets. I think when they a properly cooled, properly powered and have excessive power limits set they should theoretically do the same clock.
I've never tried to overclock mine individually because I run out of power before I can max them out. There isn't much difference between them though, one can do a single bin higher on the core and the other will go an extra ~100MHz on the memory.
JR
  #16
Old 02-04-15, 03:25 PM
Kaapstad's Avatar
OC3D Elite
Some people do the above.
It is also a good idea to put the fastest card in slot one
The next fastest in slot three (in case you want to run 2 way SLI).
The third fastest in slot two
The slowest in slot four.
If you have the fastest card in slot one it can also pull a tiny bit more performance out of the slower cards, more so in a two way system.
Sleeping Dogs @2160p
5960X @4.5
Titan X @1405/2002
Settings Maxed
Single card
4 cards
Hitman benchmark max settings.
Single TitanX @1526/2002
5960X @2002
350.05 Drivers
1080p
2160p
__________________
#041
  #17
Old 07-04-15, 01:14 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Just use Precision X or Afterburner to sync the clocks and lock them to the same frequency.
__________________
"Those really high 20 series prices are just place holders"
  #18
Old 18-04-15, 07:27 AM
Kaapstad's Avatar
OC3D Elite
5960X @4.5
4 x TitanX @1455/2002
2160p
350.12 Drivers
This is what I normally do but even then they will still boost to different levels.
Here is a Heaven 4 bench maxed @1440p, it is a higher score than the original Titans could do @1080p
4 X TitanX @1480/2002
5960X @4.5
1440p
350.05 Drivers
5960X @4.0
2160p
350.05 Drivers
__________________
#041
  #19
Old 18-04-15, 07:30 AM
Dawelio's Avatar
Dawelio Dawelio is online now
OC3D Elite
For people who have Titan X's, how will one perform in Battlefield 4 on Ultra at 1440p?...
And also, how are the noise levels etc of the cooler under heavy load?... is it loud?...
  #20
Old 18-04-15, 04:46 PM
Kaapstad's Avatar
OC3D Elite
The cooler can be a little noisy much the same as the original Titans was.
You can set a custom fan profile which helps.
Most people don't have a problem with the cooler but a few do not like it.
As to BF4 I will give it a run next time I am off work but IIRC a single Titan X should max it @1440p.
__________________
#041
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
