Go Back   OC3D Forums > [OC3D] Forum Teams > [OC3D] Benchmark Team
Thread Tools Display Modes
  #41
Old 15-10-14, 12:23 PM
tinytomlogan's Avatar
The Guvnor
Originally Posted by mihapiha View Post
Thanks guys. I'm no longer that much into overclocking. I prefer not to torture my system too much. It took way too long to build it and it went to much energy into it. And to top it of, I have a pretty bad CPU...
That voltage is correct - unfortunately...
Here is probably my best contribution:
Old Folding Farm. Too bad TTL didn't set to all the threads in his Cinebench 11.5 bench-run. He reviewed the 12 core Intel Xeons a while ago, but he didn't set CineBench to utilize all cores. It automatically sets itself to 32 threads max. I wonder if the Xeons would have come close...
Ive got a pair of 18 core beauties coming
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #42
Old 15-10-14, 12:34 PM
The Guvnor
I should have the 18 core beauties arriving soon
__________________
  #43
Old 15-10-14, 12:35 PM
MadShadow MadShadow is offline
OC3D Elite
Awesome
__________________
|i5 4460|8GB RAM|R9 380 4GB|ASUS Z97-I Plus|WD Blue 1TB|Corsair RM650|Phanteks Enthoo EVOLV ITX|
  #44
Old 15-10-14, 03:28 PM
kilobravo kilobravo is offline
OC3D Elite
Send a message via MSN to kilobravo
Talking Lucky draw
Looks as if i have won me a nice hardware bundle.
8gb 2800mhz hyperx
Z97 soc force
10g gelid extreme
240gb hyperx 3k ssd
CM nepton 140xl
CM v750s
http://hwbot.org/competition/hyperxhot14emea
__________________
  #45
Old 15-10-14, 03:30 PM
mihapiha's Avatar
mihapiha mihapiha is offline
Advanced Member
This time set up the CineBench run right
__________________
best regards
mihapiha
Rigs:
primary computer: MacBook Pro Retina 15"
gaming computer: Blue Obsidian
  #46
Old 15-10-14, 03:40 PM
Tripp's Avatar
Tripp Tripp is offline
too many shrooms
8gb 2800mhz hyperx
Z97 soc force
10g gelid extreme
240gb hyperx 3k ssd
CM nepton 140xl
CM v750s
Congrats buddy you won a nice prize there
  #47
Old 20-04-15, 09:14 PM
OC3D Elite
Got Lucky with a 5960X.Doing 4.8ghz-1.35v at 3000mhz 14-14-14-25-2T ram.Gotta love R5E.
__________________
  #48
Old 03-07-15, 05:31 PM
OC3D Elite
Had my 1st experience with ln2,and whilst good for DICE,my subzero pot cant handle a 5960x running 350w+ without careful monitoring temps.My octocore couldnt handle below -95c where it would hardlock blackscreening and was difficult administering ln2.Soo the gap from -192c to -95c was hard to handle.But 5730mhz is quite honorable,beating some off the heavy benchers.
Hwbot prime at 5730mhz with a 5960x isnt that bad.
http://hwbot.org/submission/2911636_...0x_9401.84_pps
__________________
  #49
Old 04-07-15, 09:02 PM
Rasmus66's Avatar
Rasmus66 Rasmus66 is offline
Advanced Member
You need a propane blowtorch m8.
It has to be similar to the one on the picture.
The trick is to cool the pot down to about -80 c then hit it with the torch for about 30 sec then pour ln2 again.
Like Splave does in this video.
It will go in to a sort of pull down mode where it reacts very fast to just a tiny bit of ln2 making it easier to control the temperature
__________________
Voltage - The cause and the solution to all our problems
  #50
Old 05-07-15, 08:59 AM
OC3D Elite
Will have one for next session.Thanks for the advice mate.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
