Go Back   OC3D Forums > [OC3D] General Forums > OC3D Reviews & Videos
  #41
Old 16-05-17, 08:50 PM
BigDaddyKong's Avatar
BigDaddyKong BigDaddyKong is offline
OC3D Elite
That wi-fi edition is supposed to be identical to whats out now, only the module with a $25.00 price increase.
__________________
AMD R7 1800X-Asus Crosshair VI Hero-16GB GSkill 3200mhz-Corsair HX850-H110i-MSI 1070-Coolermast H500-Windows 10 Pro-Dell U3011-Dell 2007FP
  #42
Old 16-05-17, 09:49 PM
Stereo Stereo is offline
Newbie
25$ would be great !!! I had already decided to buy CH6 and looked around to add wifi and Bluetooth (25$ dongle and about 100 for wifi card in CAN total 125$) so the addition of this saves me around 90$ Canadian and frees up a slot.
Now the only problem is when will it be available, considering I was all set to start build in about 15 days or so. Waiting for computer May 30 press conference to see VEGA
  #43
Old 17-05-17, 12:03 PM
OC3D Elite
If you don't want to wait, the slot and cutout is already there in the back plate. You can buy a laptop card and fit it there for about the same price. Just make sure you do it before you install the board.
__________________
  #44
Old 23-05-17, 04:31 AM
nestoche nestoche is offline
Newbie
Can TinyTom or anyone check to see if the NZXT internal hub works with the Crosshair VI Hero X370?
I recently purchased one from Amazon as an open box and it doesn't seem to work. I tried to plug my H100i water cooler dongle and the case front headers to the NZXT hub but I get no signal/power....Is there a problem with the Asus RoG internal USB hub that won't work with any hub extension? If I plug the H100i dongle or the case headers straight to the MB then it does work, but with the NZXT hub it's a no go.
Can anyone who has this MB and NZXT hub verify if it does indeed work? If it does, then I might have a defective hub and need to return it.....Thanks in advance!
  #45
Old 23-05-17, 09:50 AM
tinytomlogan's Avatar
The Guvnor
Sounds like your hub is faulty
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #46
Old 23-05-17, 03:38 PM
Newbie
Thanks Tom,
Yea, that's what I thought was the problem. I returned the Amazon open box and I am going to my local computer store and pick-up a new one.
  #47
Old 07-06-17, 08:00 AM
Daiyus's Avatar
Daiyus Daiyus is offline
OC3D Crew
Will you be reviewing the B350-f and X370-f?
  #48
Old 07-06-17, 09:20 AM
The Guvnor
X370 is here.... When Ill get to it IDK though
__________________
  #49
Old 07-06-17, 10:17 AM
Daiyus's Avatar
OC3D Crew
Nice. No rush, was just wondering. Thank you.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
