Go Back   OC3D Forums > [OC3D] General Forums > OC3D Reviews & Videos
  #21
Old 13-03-17, 01:47 PM
Shingara Shingara is offline
Member
I thought the hero had 2 sets of phases, 8+4, 8 for cpu, 4 for ram.
or am i misunderstanding what you mean ?
  #22
Old 13-03-17, 01:54 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Which hero?
__________________
If you don't like what I post don't read it.
  #23
Old 13-03-17, 01:58 PM
Member
Originally Posted by AlienALX View Post
Which hero?
yes, crosshair hero
  #24
Old 13-03-17, 02:10 PM
Firedrops Firedrops is offline
Newbie
Looking at the ROG hero it seems there is only one set of phases. If you look at the power connector at the top of the board you will see it only has one 8 pin.
If you then look at the audio circuitry on the Z270 you will see six small Nichicon gold capacitors. There are far more on the Crosshair.
The power phases on the Z270 will need to be tiny compared to the Crosshair. The Z270 is a board made to run at the very most four cores and four HT threads. That's it. The Crosshair needs a metric ton of phases to handle CPUs double that (so 8 cores 16 threads) this means you need bigger phases and more of them.
The only similarities between the boards is the "hero" name. I don't know why Asus did that. You should be comparing the CHVI to the Rampage or something as high end as that.
I guarantee if this was an Intel board it would cost far more. Intel charge quite a large socket tax, chipset price etc.
Thanks! Those seem like reasonable explanations that I failed to notice on my own - I just assumed it's the same level of componentry, given the same name/tier.
One question though: doesn't phase design requirement depend on the CPU power draw, not the core/threads?
  #25
Old 13-03-17, 02:34 PM
AlienALX's Avatar
OC3D Elite
yes, crosshair hero
Ah OK (darn you Asus !!). Yeah, it has extra phases which means extra cash.
__________________
  #26
Old 13-03-17, 07:00 PM
Seikusa Seikusa is offline
Newbie
Hi,
Thanks for the Review Tinytomlogan,
I would like to ask if you tried to fit the Noctua DH 15 with the AM3 mounting on it?
Or is it neccesary to use the am4 mounting?
Greetings
  #27
Old 13-03-17, 07:12 PM
Avet's Avatar
Avet Avet is offline
OC3D Elite
Crosshair VI Hero has 8 phases for CPU, 4 for SOC, and 2 for RAM.
Detailed review of VRM is in this video:
  #28
Old 16-03-17, 06:55 AM
Masterofevil22 Masterofevil22 is offline
Newbie
Smile Exact RAM used for your 3333mhz OC?
Hey Tom,
Great video mate. I always enjoy em! I just got the Crosshair VI and a Ryzen 1700 CPU. I put a 16Gb kit of G.Skill 3400mhz in it from my previous z170 skylake system. I tried to post and it gives me error code #8. Is this ram just not compatible Yet? I see the 3200mhz variant listed...but not the 3400mhz kit...of course
In any case, what was the exact ram that you used to get your system to 3333Mhz? Was it the Corsair LPX 3200Mhz 16Gb kit?
Also, would you mind listing your exact ram voltage and other bios settings as well, just for a point of reference?
Thank You a Ton!!!
XBnPC
  #29
Old 18-03-17, 12:14 AM
Newbie
Originally Posted by Masterofevil22 View Post
Hey Tom,
Thank You a Ton!!!
XBnPC
We'll, I went ahead and bought that ram, so I hope it works as it did in your review. Thanks to everyone who responded for all your help.. such a thriving community helpful techies on here
  #30
Old 18-03-17, 01:36 AM
BigDaddyKong's Avatar
BigDaddyKong BigDaddyKong is offline
OC3D Elite
Has anyone else had problems with board just chucking a fit when using a DOC profile 1. I can set 3200 manually, and it runs fine. I use DOC and it throws out all stability.
Also, what is everyone seeing for vdroop on this board. Mine is pretty bad. I set vcore at 1.4, with LLC on level 4 and I am still at 1.35 under load. That with max current turned up to 120%.
__________________
AMD R7 1800X-Asus Crosshair VI Hero-16GB GSkill 3200mhz-Corsair HX850-H110i-MSI 1070-Coolermast H500-Windows 10 Pro-Dell U3011-Dell 2007FP
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
