  #11
Old 22-04-20, 08:56 AM
The_Crapman's Avatar
The_Crapman The_Crapman is offline
Newbie
It's kind of similar in that it has those side mounted fans, which Lian Li have been doing for a while now, but it's all the rage in case design now with everyone doing it, just like roof mounted fans and psu shrouds before that. This has a bit more of a showcase-ness to it with the glass roof while still having really good ventilation up there, more room in the main chamber for a plethora of watercooling gear, as well as being able to mount a rad/fans up front if you choose. It also has the advantage over the 011D of having built in rotatable PCI slots.
The side mounted fans on this can also be shifted to the front or back by a cm or 2 (for 120mm anyway), to give you more wriggle room, something I wish the 011D had when I recently did a build in one.
  #12
Old 22-04-20, 08:39 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
Are you gonna be building the internals back in the same as the test fit?
__________________
ASUS ROG Crosshair VII wifi | Ryzen 5 3600 | Custom Loop | Patriot Viper Steel 4133 @ 3600 2 x 8Gb | Asus Strix RX 470 | Samsung 500gb nvme | Samsung 1Tb nvme | Samsung Evo 120gb ssd | Seagate Barracuda 1tb storage | Toshiba 1Tb HDD | EVGA 500w | Phanteks Entho Pro Tempered Glass | Windows 10 and Linux Manjaro
  #13
Old 22-04-20, 09:12 PM
Newbie
The loop will be completely different, that was just a quick and dirty soft tube job with spare parts I had. The test fit was more about getting to know the space of the case and making sure the hardware worked. When I'm coming up with ideas and planning stuff in my head, I have a habit of thinking cases are much bigger than they are or components are much smaller than they are, then when I come to implement them.....
During the build I was sticking this and that in various holes to see how it fit and what adjustments or mods I'd need to do to get everything to work like I wanted, or if I'd need to change my plans. Having never used RGB fans before, the headache (and ball ache) of the cables convinced me that I'd need to do custom cables.
  #14
Old 23-04-20, 05:28 AM
Avet's Avatar
Avet Avet is offline
OC3D Elite
Originally Posted by Dawelio View Post
That ThermalTake case looks very identical to the Lian Li PC-011 Dynamic (or whatever it’s name is), which was made in partnership with der8auer.
Der8auer's comment on O11 dynamic "replicas" was: "I am surprised it took them that long."
__________________
Turbos on an engine is God's way of telling you it ain't got enough cylinders.
  #15
Old 25-04-20, 07:21 PM
Newbie
More Destruction!
Hi-diddly-hey modderinos!
I've not been too well over the last week, fortunately not from you know what, but it has meant there hasn't been an awful lot of progress. I haven't been completely idle though. I've done a few test fittings as the odd part has come in and done some detail plans for some of the things that weren't fully fleshed out. I've also had some more destruction equipment turn up, so toward the end of the week I got back to it.
First on the agenda was to continue the "ageing process" and try and blend the side panel into the rest of the case. After I'd finished the side panel I was a little concerned that maybe I should have had the panel on and been doing it in-situ, but I needn't have been.
Being a bit of a clumsy oaf and having dropped more than my fair share of computers, I know they can get a bit dented and nicked around the bottom edge. What better way to expedite that than the pointy end of a hammer.
I had been using my Dremel with the stand just on the floor. It had fallen over a couple of times and wasn't exactly the ideal orientation for free use of the flexible shaft (quieten down ), so I rigged up something a bit more secure that would allow better movement and it helped no end in getting in to it at the right angle (I said quiet in the back! )
I want to try and make sure there are nice little touches here and there, things that may not be immediately obvious or possibly hidden from view, but it's those little flourishes that can make all the difference. In particular I want to try and put in little touches of wear where there would be from actual natural use, not just outright destruction. The little HDD access panel at the back seemed like a prime candidate for just such a thing, where the 2 tabs sit into the case.
Taking my trusty 'not for wood any more' chisel, I slowly ground down into the paint and I tried to do it with the same kind of small pivoting motions you'd get from moving the panel about.
And not forgetting the panel itself of course.
I'm not going to be using the fan filter on the bottom of the case and the tabs that stick out to hold it in place are no longer required.
They also kept getting caught on stuff and it got annoying so.....
There's also something else missing here. Care to guess what?
Can you tell what it is yet?
You might be thinking I've gone completely nuts at this point and of course you'd be right, but I went mad long before now. Muwah ha ha ha haaaaaaaa! Don't worry it'll all make sense eventually. I hope. lol
Next up for ruination are the door hinges. First up a little sanding, trying to swing round as the door would and make it look like natural wear.
Then I took them out so they could spend a little time with Mr Dremel the Destructor. I used this pointy grinding bit to get in the nook of the screw threads on the first one, which was a bad choice as it left a lot of score lines.
I switched over to the abrasive wheels for the other side and the other hinge.
Of course when I go to put them back in I drop one of the screws, it bounces once then down through the crack in the floorboards of the shed. So I go in search of a replacement, I've got loads of screws from this and that, one is bound to fit. First stop is the screw tin.
I didn't find a screw that matched, but it did appear to be the same thread as a motherboard stand-off, so off to my bag of screws to find an M3.5
No luck there either so we turn to the tin of last resorts, where screws go to die, there must be something in here.....
Ah. Just whole bunch of junk and tat So armed with the remaining screw and a stand-off I went back to check that was indeed the size.
Success! So I ordered some nice shiney nickel plated replacements. Probably for the best anyway, black ones would look a little daft once all those rivets have been removed. But that's for another day.....
..... as is this rather large parcel.
That's all for now folks. Will you ever find out what's in the box, or what's happening to the rivets? Stay tuned Crapfans! Same Crap time, same Crap Channel.
__________________
Project I.S.A.C. Project Log
Current Rig:i7 [email protected] w/ Heatkiller IV Pro Pure Copper, ASUS Z270i, 16GB Patriot Viper 4 3400MHz CL16, Zotac GTX 980Ti [email protected]/7804 w/ Custom Copper Watercool Heatkiller IV XL, Samsung 256GB 960 EVO M.2 and 120GB 840 EVO SSD, XSPC Twin DDC Dual Bay Res w/ 2x Laing DDC-1T Plus on watercooled Alphacool Heatmaster II, 2x 240mm Alphacool ST30 w/ EK Furious Vardar EVO fans on watercooled Aquearo 6LT, EKWB Cryofuel Clear, Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
  #16
Old 10-05-20, 01:08 PM
Newbie
An Open Letter To No Work
I just wanted to apologise for the lack of progress and updates, as since the last episode of Project I.S.A.C. I've not been very well. I have nerve damage from a botched hernia operation and subsequent ill-advised treatment, so I have to be a careful with any kind of physical activity. After the last break due to a stomach complaint, I pushed a bit too hard in an effort to try and catch up and ended up aggravating the nerves and have had to take a couple of weeks to let that die down and concentrate on my physio (all 3.5hours a day of it!). Even though I've been feeling a lot better and doing some stuff around the house, just yesterday I was in a lot of pain after 10-15mins of washing up. It's immensely frustrating.
I'm not after any sympathy, so put the violins away, just a little understanding that whilst I'll do my best to bring you an update and some meaningful progress each week, there may be times when I have to down Dremel and look after myself.
There should be a little update video being pushed out by Thermaltake tomorrow, be sure to keep an eye out for that. For now I'll begetting on with a few little bits and pieces of 'lighter' work, so stay tuned Crapfans! Same Crap time, same Crap Channel.
__________________
  #17
Old 18-05-20, 05:06 PM
Newbie
That mobo's gotta go
Ahoy hoy mod fans!
While I was waiting for the rest of the parts to turn up before I could do anything further on the case, I set my sights on some of the internals that could do with some tweaking.
I needed to brighten the motherboard up as the main chamber of the case will have a bare metal finish and it would look like a black hole in amongst all the bright shiney metal. I've also never been much of a fan of modern motherboard heatsinks. I loved the fin-stacked heat-piped up solutions of yore and I'd even kept the one's off the Striker II NSE/Extreme boards for the ages after I'd binned the boards, but lost them in a move. What I did have was some Thermalright MOFSET heatsinks and a beefy Supermicro 1U copper cpu heatsink that I could use instead of or in combination with the existing ones
Time to get this board stripped down.
The CPU heatsink's mounting holes lined up perfectly with the mounting holes for the cover, almost like it was made to live there.
Not sure it's supposed to come out like that
Was very lucky not to strip any pins out of the CPU. Can just imagine how well that conversation would have gone down with Thermaltake After that heart exploding moment I gave the CPU, block and board a bit of a cleansing.
This was the kind of setup I was looking at doing. I plan on milling a flat channel into the boards original heatsinks and using thermal glue to attach the Thermalright MOFSET heatsinks to them, rather than on there own. MOFSET sizes have grown a bit since these were made! There may be a bit of a fitting issue for the one on the left side MOFSET bank as it clashes a little with the IO shield. I'd rather keep that intact if possible.
Those original heatsinks would still be too dark as is though, so we'll have to do something about that gun metal grey anodising. First off taking the fan off the chipset cooler, stripping the thermal pads (after measuring the sizes for their replacement) and giving them a good clean with TIM cleaner to remove the grease from the thermal pads, before they go for a little dip.....
... in some of this horrid stuff. Also know as Sodium Hydroxide.
I'd picked up these old sweet containers to bathe the parts in and then rinse. Sadly I didn't get to eat the contents first, but given my ever increasing waistline that's probably for the best.
I'd given them a good clean several times over and then a thorough rinse as I didn't want any contaminants in there that may react with the Sodium Hydroxide.
You'll have to forgive me for the lack of pictures of the process, I was dolled up to the 9's in PPE (including a waterproof coat with a bin bag over it, was quite a sight) and didn't fancy getting my phone out whilst in the middle of it all. I placed the 3 tubs in the bath, seemed like a good place to do it as there's good ventilation in the bathroom and if things go south it can turn the taps on and ditch it down the drain quick. With the drain on my left, I used the left most container to have the solution in. I filled the other 2 with water as a 2 stage rinsing set up. I put 1 litre of water into the other and added 50g of sodium hydroxide crystals in gradually, in about 5 or 6 stages, mixing thoroughly with a toothbrush I had to scrub the pieces as the anodising came off. I used cold water to control/slow the reaction a bit so I could leave the pieces in long enough to get all the anodising off, without it just eating the aluminium away
I put the large MOFSET cooler in first as I figured it could probably do with going in when it was fresh. It took a little while to get going and do anything, but sure enough bubbles started to come. I turned it over a few times, giving a little whirl in the fluid and you could see the colour fall off it. I then started giving it a helping hand with the toothbrush, especially in the little gaps. When the anodising had all come off I pulled it out and gave it a gentle shake, dropped it into the next tub with the clean water in, gave it a good whirl in there and and gentle clean with a second tooth brush, then into the third container for more fresh water, before finally putting it on some kitchen towels I'd set to the side to dry off. I then repeated the process with the rest of the pieces.
The end result was better than I ever could have imagined
The Aluminium on the newly stripped heatsinks is so bright, almost white. Look how it contrasts here to a peice of Aluminium sheet that I've had for a few years.
And they look so good on the motherboard too! Super chuffed with the result. At least 3 chufty badges!
Sadly the copper cpu block isn't going to fit, although given it's gargantuan size it shouldn't be all that surprising. I could have had a go at cutting off a corner here and there to get it to fit, but I don't think I've got the tools for the job and I'd probably end up ruining it. In all honesty with the amount of silver that's going to be around, the copper would probably look out of place anyway. Best to keep that for another day.
I had a little test fit with the MOFSET heatsinks, either just sat on or with the help of an old thermal pad. Still not convinced that one on the left if going to fit without interfering with the IO shield.
Thought I could maybe switch that one to the lower M.2 slot cooler.
In all honesty I'm not entirely convinced. Now I've got the stock heatsinks stripped, they look pretty dam cool. I have to be 100% sure as if I commit to it and it doesn't look good with the heatsinks on, I'll have wrecked the originals, so there's no going back. That can go on the back burner for now. There's a lot to be done still and I can always come beck to it later. It does look pretty dam sweet as is though.
We got some new parts!
Huge thanks to the guys at Scan (and DPD) for getting these over to us.
Lots of fittings and adapters, a couple of litres of coolant, some 1m tubes for longer runs and backup for the inevitable -ups, a nice thick rad and 9 of Thermaltake's new Riing Quad fans which I'm looking forward to getting snazzy with the NeonMaker software. I am NOT looking forward to the cable/sleeving job of those 9 RGB fans
Now putting heatsinks to one side, I'm still not done with the motherboard and whilst I have done some more stuff, it's not finished and I don't want to put it out half baked. I had hoped to finish it today but after 3 days of working on it on and off, this morning my body said no. This seemed like a good place as any for a little update though, I hope you all enjoyed the show. For now I'll leave you with one last shot of those heatsinks in all their glittery glory. Hopefully I'll have another update for you later this week, so stay tuned crap fans! Same Crap Time, same Crap channel.
__________________
  #18
Old 23-05-20, 01:36 PM
Newbie
Motherboard Metal Madness
Gooood Moooorning Modding faaaaaaans!
So with the motherboard heatsinks nicely brightened I couldn't just stick that black plastic shroud back over them. Luckily I have some 2mm aluminium laying about that I've had forever and this will make an ideal replacement. I started by tracing round the the original cover, but because it has mounting struts and other stuff underneath, this was better done turned upside down to get it flush(er) against the paper, which is why the drawing is backwards. Then I took measurements for the rest of the board so that I could expand it out a bit and cover up more of the motherboard.
This is the area I want to cover, colour coding showing the original and then different additional bit that I might want to add.
I did the drawing on card so that it would stay relatively flat once cut out and got it lined up with the mounting point and punched them through. Once on the board it didn't look right having a lot of square corners given the boards original angular designs, so I marked out bits I'd want tweaking with rough angles from the heatsinks.
Back off the board I used the cover to get the proper angles and see about different levels of cropping.
Couple of snips later and I think we have a winner!
Now this was a fairly rough drawing so I then traced round this template in pencil and took to the drawing board to get all the lines true.
Again I used the original to get the angled lines in, it was an awkward angle and I don't have anything like a sliding bevel. I could still find ones that were out like the one I circled in orange.
With a couple of lines done this way I then turned the paper so the the angle was horizontal, checked them against each other to make sure they were correct and then filled in the rest. With the design completed I did a couple of photocopies and also scanned it for safe keeping.
From right to left we have the original plan, the final design, the photocopy to be used as a template and the aluminium, with the original cover centre and glue to stick the template on.
Only that's completely the wrong glue Looks more like spider spooge.
Still, it stuck that template down pretty good, if a little on the lumpy side. I also had to rub dirt around the edges where there was no paper to remove the tackiness of the glue and stop the jigsaw from sticking.
That very morning I had been reading up on a scratch build someone was doing as their first mod and advising him on how to cut outside the line and file in, so what do I do on the very first cut? Cut BANG ON the line It was the edge on the far right next to the SATA ports so wasn't a complete catastrophe, but was very careful and took my time with the rest and came out fine, although the small vertical edge under the angular protrusion top right was hard to get at.
The Filing went ok, I'd bought a set of steel jaws for the workbench to clamp it in which helped keep it nice and steady. This tight angle was tough though as I didn't have a triangular file that matched or was under that radius. i had to edge in with the half round file, flipping it over every few strokes.
A bit of folded sand paper helped get it a bit tighter, but it put up a good fight,
Took a good lot of doing, had to go at it in a few goes to save me from injury. But was all this mess worth it?
It fits!
There were a couple of areas that needed work that I highlighted in green, either to straighten them up, change the angle or stop it overhanging headers I'll need access to.
Bang on.
To get it to sit flush in the recesses of the M.2 heatsinks I needed to drill holes for the screws holding the heatsinks down. To mark where they were I put masking tape on the back, coloured the screw heads with whiteboard marker and pushed the piece onto them, being careful that it lined up with where it needed to sit. Seemed to work well.
I used a punch to mark the centre and make sure the drill bit didn't wander.
I thought the screw heads were 4mm so I drill a hole with a 4.2mm bit to give a little wiggle room, but I must have measure the wrong screws (the ones that will mount this to the motherboard i think) as they were a little too small. I needed 5.37mm holes minimum.
My step bit had a 7/32" step which is 5.56mm ( ) and would do the job nicely. Unfortunately, due to either a wandering bit or inaccuracies in how I got the positioning the top hole was just out.
To be honest I wasn't THAT upset. There were a few edges that were a bit naff and there were a couple of tweaks I wanted to make, so I widened those holes a fair bit so I could get it into place, check the fitment elsewhere and make sure the markings for the mounting holes were accurate, which they were.
And just for fun I took off the paper and gave it a really quick and dirty "brushing" with a washing up scotch pad, but was mostly just from trying to get all that nasty glue off. Still looks pretty tasty
It's a shame it's going to end up in the recycling, but for a first whack it's not gone too badly. I had prepared myself that it might take a couple of goes to get it right and with the design tweaks for Mk II already in my head, I wouldn't have been happy till I'd redone it anyway. So stay tuned crap fans! Plenty more of Makin's metal manipulation to come. Same Crap time, same Crap channel.
__________________
  #19
Old 23-05-20, 01:39 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Velly noice.
__________________
If you don't like what I post don't read it.
  #20
Old 23-05-20, 10:09 PM
Bartacus Bartacus is offline
OC3D Elite
I second that, looks like it turned out great!
__________________
Games: Ryzen 5950X on GB Aorus Master X570 / Asus TUF 6900XT / 32GB TridentZ Neo 3600CL16 (16GB x 2) / custom loop
Workstation: Threadripper 2950x on GB Aorus Xtreme X399 / Zotac 2080ti / 32GB TridentZ 3200CL14 (8GB x 4) / custom loop
Home Theatre: Ryzen 3900X on Asus C7H X470 / Radeon VII / 16GB G.Skill 3600CL15 (8GB x 2)
/ custom loop
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
