Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
  #1
Old 23-05-15, 11:31 AM
crap-at-games crap-at-games is offline
Member
water cooling kits
hi guys and girls
I have been toying with the idea of doing water cooling for ages. And was just wondering if would be best to start off with a watercooling kit. As you seem to get everything you need like this one ( http://www.scan.co.uk/products/ek-ki...0mm-fitting-ek ).Or would it be best to buy individual parts.I have seen toms video in which he uses a kit.At the moment i would just like to do the cpu but if goes well would progress to my gpu as well.Any advice would be most appreciated.Also i dont know which is best a bay reservoir or tube reservoir.So like i say all help will be took on board and then i could make a decision thanks in advance
  #2
Old 23-05-15, 12:10 PM
Remmy's Avatar
Remmy Remmy is offline
OC3D Elite
As it's your first time watercooling, kits do make it really easy to get to grips with at first, as all the components will be compatible (size of fittings, no bad reactions between different metals etc), and it contains everything you need. However, if you're already looking ahead to incorporate other things into the loop like your GPU, then you're probably going to end up just replacing some of the things that came in the kit and spending more money overall. In the short term a custom loop will probably be more expensive, but it will work out better if you end up replacing some of the components from the kit.
I got an EK kit a couple of years ago, and I very quickly outgrew it. I added 2 GPUs, got 2 new radiators, a new reservoir, and a new pump. In fact the only thing I still have that came in the kit is the CPU block.
It's a bit more difficult to make sure you have everything if you do a custom loop, but I think it's worth it. You can choose all the different parts instead of being stuck with what EK gives you, and you can future proof it too, so if you want to add your GPU you could get a better pump than the EK 2.2 that's in the kit for instance.
As long as you feel confident putting it together yourself, you should go custom in my opinion. Just ensure that blocks are compatible with your CPU socket/graphics card, radiators will fit in your case (remembering to include space for the end tanks, fans, and fittings), don't mix aluminium blocks with other metals, and make sure that the fittings and tubing fit each other.
As for bay or tube reservoir, go for which you prefer, or which you have the room for, but bear in mind that if you have a bay reservoir with a built in pump, they often are quite noisy, and it's difficult to dampen their vibrations against the case.
__________________
  #3
Old 23-05-15, 12:44 PM
Member
Hi Remmy
Thanks for your reply and i think i will have to look at getting some bits and pieces together for a custom loop then and that way as you say i could add to it in the future once again thanks
  #4
Old 23-05-15, 01:28 PM
Remmy's Avatar
OC3D Elite
No worries, if you've got any questions about putting together a list of items for the loop I'll be happy to help.
__________________
  #5
Old 23-05-15, 02:05 PM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
Hi there TBH you are better off getting advice from the guys here as to buying a kit I just replaced my XSPC X20 750 pump for a D5 and the X20 750 pump was from a kit and only 2 months old.
From my own experience just get the parts individually otherwise it costs a lot more in the long run
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
  #6
Old 23-05-15, 02:07 PM
JR23 JR23 is offline
OC3D Elite
If you start out with a D5 vario, nice CPU block and EK PE or XSPC AX rad then you will keep them for a lot longer... so I think aside some of the top end XSPC kits they probably aren't the way to go if you intend to expand. And if you don't intend to expand then you may as well get an AIO like the Kelvin which you can still take apart and play with.
Essentially just look up everything you would buy individually and if you find it all in a kit and it's cheaper then go for that.
There are a few options with resevoirs, tube or bay but also including the pump or not. What option works out best will depend on your case and what you find aesthetically pleasing. Getting a resevoir that replaces the pump top can often save you some space and eliminate the need for one extra piece of tubing which could make it much neater. If you buy everything individually them you have a lot more freedom to get the parts you prefer. Re-assembling a pump with a different top or res is very easy and accessories are quite cheap compared to the pump itself so you can always change your mind.
JR
  #7
Old 10-07-15, 07:56 PM
Member
hi again as i have been advised by JR23 i have now invested some money in a d5 vario pump and also 2 XSPC EX240 radiators and now i need a bit more help im looking for a 150mm reservoir and i was looking for something like this and wondered if someone could point me in the direction of achieving this many thanks
  #8
Old 10-07-15, 11:07 PM
paulstung's Avatar
paulstung paulstung is offline
OC3D Elite
You'll need a few parts mate, firstly the res, a Bitspower Z, 40mm 100mm, 150mm, 250mm, or 400mm https://www.overclockers.co.uk/showp...962&catid=2133 it comes in a few colours
Then the pump top, https://www.overclockers.co.uk/showp...41&subcat=2143
Then you'll need the mod kit, https://www.overclockers.co.uk/showp...41&subcat=2143
There is also the bit that connects the res to the pump top, but I have no clue where to find that piece in the Uk, http://bitspowerwork.com/html/produc...oducts_id=3135
You can also get it in a few different pieces, but as far as I'm aware, not here in the uk, http://bitspowerwork.com/html/produc...oducts_id=3050
http://bitspowerwork.com/html/produc...oducts_id=1401
http://bitspowerwork.com/html/produc...oducts_id=1398
they sell them over at Highflow.nl too mate
  #9
Old 11-07-15, 06:56 AM
Member
hi paul thanks for the info just a question if i get this
http://www.highflow.nl/pompen/laing-...50p-bkibl.html
does that not include this item
http://www.highflow.nl/pompen/laing-...-dsrap-bk.html
or am i missing something lol
  #10
Old 11-07-15, 11:25 AM
Member
hi again failing to get this setup does anyone know if i could make this up useing other pieces ie xspc or something similar many thanks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
