  #11
Old 13-09-13, 10:45 AM
Mark3Max Mark3Max is offline
OC3D Crew
According to Gigabyte's website the G1 Sniper 5 measures 30.4cm x 26.4cm.
Looking at my 650D , that's going to cover the three cable grommets on the left
( the standard atx grommets ).
I'm not sure if the standoffs will line up , but you just need run your sata cables under the motherboard .
__________________
Corsair 650D, MSI Z77A-GD65 , I7-3770k, Corsair H100i w/sp120 QE ,G.Skill Ares 16gb 2133 c9, Asus Blu-Ray Burner, Asus Xonar STX ,Corsair Neutron GTX 240gb ,W.D. black 1TB ,Seagate 3TB, MSI GTX 680 Lightning, Corsair AX760i ,Case Fans : Front : CM 200 blue,Rear : Corsair AF 120 PE , Klipsch 2.1 , Sennheiser HD650 , 2 x Samsung 23" 1080p , Logitech G710+
  #12
Old 13-09-13, 02:14 PM
Tex Lomar's Avatar
Tex Lomar Tex Lomar is offline
Newbie
I was browsing the subject of whether it would fit, or not and I found a few threads where people managed to fit other E-ATX boards into that chassis. One was a Gigabyte Sniper G1. 3, and the other was an MSI, iirc.
Do you think I could just tuck them under a bit and fit them through the grommets?
Ok.. I just watched that vid... there looks to be plenty of room for the mobo I want. Thank you for that video.
  #13
Old 13-09-13, 02:38 PM
garih garih is offline
OC3D Crew
no problem, whatever the problem, there is usually a YouTube video to help,
thanks to TTL for being so in-depth with his reviews
__________________
  #14
Old 13-09-13, 02:58 PM
Tex Lomar's Avatar
Newbie
I'll second that... thanks Tom
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
