Go Back   OC3D Forums > [OC3D] Project Logs & Gallery > Rig Gallery
  #1
Old 15-12-12, 08:26 PM
mehere's Avatar
mehere mehere is offline
OC3D Crew
500R first time mods/playtime
this started life as a 500R what you think?
I know the detailing isnt as good as you big boys here and boy them lights are bright but they turned down since pics taken
240x80 rad in front 360x60 in roof
bit tight here but dont touch anywhere
not over happy with the window fitting but its done now no going back
all the top and front mesh/trim removed and replaced with tint plastic
  #2
Old 15-12-12, 08:58 PM
seumasbeathan seumasbeathan is offline
Banned
Im not sure if I like all the led fans, but it does look very good
  #3
Old 15-12-12, 08:59 PM
PEXON's Avatar
PEXON PEXON is offline
SleevingMaster
Send a message via Skype™ to PEXON
Way to much tubing used and that binding wrap looks naff....
__________________
El Jefe of Sleeving
  #4
Old 15-12-12, 10:26 PM
Reily234 Reily234 is offline
Newbie
Nice mods! Im not a big fan of the wrap but everything else looks awesome to me!
  #5
Old 15-12-12, 10:31 PM
dalewakelin's Avatar
dalewakelin dalewakelin is offline
OC3D Elite
Send a message via Skype™ to dalewakelin
Looks nice
__________________
  #6
Old 15-12-12, 11:32 PM
wriskshadow wriskshadow is offline
Newbie
O lord my eyes so bright... can you even use that at night without going blind? but that looks pretty cool
  #7
Old 16-12-12, 08:07 AM
mehere's Avatar
OC3D Crew
morning all thanks for the replies the brightness is reduced now I put a fan rpm reducer on them
the wrap it not the best stuff to use but money is short and it was to hand tube between gpu's needed some so function came before form changing it farther down the road
  #8
Old 16-12-12, 12:37 PM
yassarikhan786's Avatar
yassarikhan786 yassarikhan786 is offline
OC3D Elite
I have to agree with Pexon, the tubing wrap does not look good. If you removed that and most of the LED's it would look much better imo.
P.S. These are just my opinions.
__________________
Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: EVGA GTX 780 Ti ACX || Memory: 16GB - Mushkin Blackline 8GB + Corsair Vengeance LP 8GB || SSD's + HDD's: Samsung 850 EVO 500GB (OS + Programs) + Caviar Black 2TB (Games + Storage) || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + Dell U3818DW
  #9
Old 16-12-12, 03:02 PM
tinytomlogan's Avatar
The Guvnor
Yeah sorry dude I dont like this at all.
Stuff over the tube looks cheap as fook and the grills over the rads look wrong just floating there. This is almost a kill it with fire award winning rig
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #10
Old 16-12-12, 03:56 PM
PEXON's Avatar
SleevingMaster
A little extra thought, a few more rotary fittings and you could get a much cleaner loop in there. Little things like going from the pump/res into the right hand fitting instead of the left on the GPU will make it look so much neater.
__________________
El Jefe of Sleeving
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
