Originally Posted by Harishanim
where can i find the power saving option? and its not only the 3.5GHz in cpu-z but even in the ai suite as soon as as hit back it goes back to 800GHz per core
Yes yes when it is in power saving it runs the cores at very low frequencies to use less power, it is a bios option so all application will show the same thing.
Now I can't tell you where the feature is, I'm on a completely different platform so the bios (uefi in your case) will be different than mine, using google is the least you can do at this point, I already pointed you in the right direction.
