Thread Tools Display Modes
  #11
Old 15-07-17, 12:26 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Very Nice dude very nice
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=16gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=Asus ROG Swift=Corsair K95 RGB=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #12
Old 15-07-17, 01:41 AM
stealth80 stealth80 is offline
Newbie
Thanks, it's been a long road! I literally just looked at the photos throughout this project and its a massive transformation:
It went from a Thermaltake X9 - was dual loops, SLI 970
which was too big and limited our choice of desks
to the original Temporal Snow
To the refresh which I thought was done:
(Kinda annoyed I couldn't hide the wires for SSD as I wanted to mount it in the front above the fan - but wanted to keep cables to the absolute miniumum
to today
  #13
Old 15-07-17, 07:25 AM
Surfie's Avatar
Surfie Surfie is offline
OC3D Crew
Awesome build man. Kudos to you.
I would be interested to know more about the method you used for painting the fittings. I'd be scared about paint damaging an o-ring or something.
__________________
What we've got here is; failure to communicate...
  #14
Old 15-07-17, 10:44 AM
Newbie
Thanks
The actual fittings were already white - just to be sure we're talking about the same thing
I sprayed all the rotarys and extenders. I started doing them individually by sacrificing some older rotarys and end caps therefore covering the threads and orings
After day one I realised I could just screw all the fittings together and just use one end cap and one old rotary and paint them all at the same time. I literally spent a day to 2 days doing them as I could only do a half at a time
Hope this helps
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
