Thread Tools Display Modes
  #21
Old 09-07-17, 10:21 PM
MT. Mods MT. Mods is offline
Member
Quick update*
GPU has been fitted and looking really sharp!
I love the stainless steel and black together.
  #22
Old 16-07-17, 09:55 PM
Member
Updates
getting finishing touches done, while waiting for the reservoir to re-seal (Still not happy with it, but it'll have to do)
Changed the white on teh shroud to orange, added a top rght corner with aorus logo (i'll probably change that later to black and orange).
Waiting for a few more things to arrive (RAM) and then i should be good to release final photo's, video and most importantly, results of the tests.
  #23
Old 21-07-17, 10:20 AM
Member
Well.. loop is filled and running smooth.
Currently running with a 280mm radiator right now, as the i wait for the coolants to arrive which are now heavily overdue due to stock (mayhems pastel white)
  #24
Old 21-07-17, 01:01 PM
TheF34RChannel's Avatar
TheF34RChannel TheF34RChannel is offline
OC3D Elite
Perfectionism in a case: very nice sir!
__________________
Asus Z370 Maximus X Hero | Intel Core i7-8700K 4.7GHz | Corsair H105 | G.Skill Trident Z 3333MHz CL16 16GB | Asus GTX 1080 Strix | EVGA SuperNOVA 850 P2 | Crucial MX200 500 GB | 760T | Acer XB270HU 1440p | Windows 10 Pro x64
  #25
Old 22-07-17, 03:03 PM
Member
The RAM is here! And by god is it pretty!
Fits this project perfectly, also look at how close the tube run is!
I had to adjust the height of the top run to squeeze in the RAM, but it's in now and working
Specs: 2x8GB DDR4 @3000mhz
Team Group T-Force NightHawk RGB White
  #26
Old 02-08-17, 10:47 PM
Member
Sooo.... We ran into complications with the custom res and bubble cooling.
While it works 100% well with the CPU only, it really didn't like the 1080Ti included.
In fact, the reservoir split in the bottom after 4 hours of stress testing.
So i had to quickly re-think some things to get this project done as fast as possible.
While the idea for bubble cooling may be a bust, the design idea is still in play.
From Alphacool
The Eisbecher Lite 250mm reservoir
I'm using Mayhems pastel orange coolant for this
The NexXxoS XT45 420MM Radiator
And those fittings you see are the Alphacool Eiszapfen angled adaptor 90° rotatable
I changed out the legs to something much much better and more fitting.
But i'll reveal them later this week with the finished build.
  #27
Old 07-08-17, 06:36 PM
Member
Some final photo's before it travels oversea's
(I do realise now after taking photo's that the M.2 was not screwed in lol)
Will take more after show and have someone take some during the show
  #28
Old 07-08-17, 06:48 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Nicely done sir, take a bow. I'm rather impressed and need to see more builds using Orange, love the use of stand offs for creating air flow.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #29
Old 07-08-17, 06:58 PM
Member
Thanks
Yeah, orange is very under rated, very vibrant
want to add 2 more photo's with different lighting
  #30
Old 08-08-17, 10:43 AM
Warchild Warchild is offline
OC3D Elite
Outstanding build. Love the cascade reservoir mod. Bitspower are doing this too now.
However, your logo shield is a "little" bit of an eye sore for me. I would have love to see the window without that.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
