Thread Tools Display Modes
  #21
Old 20-05-17, 01:13 AM
ciobanulx's Avatar
ciobanulx ciobanulx is offline
Advanced Member
Hi guys,
Here's most of the piping done!
One issue I had with this is that two of the pass through fittings were way too close to each other and I only had Bitspower C47 style fittings that were a bit too large. So I ended up hand filing them down.
This was the result:
Just shaved off a few mm and they fit perfectly with a bit of tubing between them.
They're the ones at the very bottom.
Mounted the RGB LED controller for the Corsair fans in the front as well. This will be accessible from the side even with the front panel on.
And here's a look at the cable management.
And now the inside.
The red chrome tubes, with the fittings in the middle is a reference to the dual lightsaber.
Thanks for checking it out and stay tuned for more!
Cheers,
Alex
  #22
Old 20-05-17, 01:53 AM
Bartacus Bartacus is offline
OC3D Elite
Love it! Those red fittings are sweet!
__________________
Guts: Ryzen R7 1700 / Asus CH6 Hero / 16GB G.Skill 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Intel 600p 1TB NVME / 6TB RAID0 array / 2TB RAID0 array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 1 240 rad / Singularity Computers reservoir / dual D5 pumps
  #23
Old 21-05-17, 12:19 AM
ciobanulx's Avatar
Advanced Member
Thanks man
  #24
Old 21-05-17, 12:43 AM
ciobanulx's Avatar
Advanced Member
Hey guys,
These were the final photos I took before getting all the panels on and finishing the build
As you can see, I went with black coolant and I also have a few red cold cathodes in there just for some more lightsaber references
Stay tuned for final pics!
Cheers,
Alex
  #25
Old 21-05-17, 02:21 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is online now
OC3D Elite
Really looking forward to seeing the final results
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=16gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=Asus ROG Swift=Corsair K95 RGB=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #26
Old 25-05-17, 08:52 AM
ciobanulx's Avatar
Advanced Member
Cheers mate! Final photos incoming :P
  #27
ciobanulx's Avatar
Advanced Member
Hi guys,
Here are the final photos! I hope you like it, I'm really happy with this one!
The only thing that might need to be changed or improved is the light behind the Darth Maul face on the front panel. The white acrylic would need to be changed to opal and get some better lighting in there so that the front panel pops nicely in the dark.
I'd like to say a huge thanks to the companies that helped me bring this project to life!
Here we go! I'll start with the outside first!
And here's the inside!
Thanks for checking it out and stay tuned for a video once I get back from COMPUTEX!
Cheers,
Alex
  #28
Old 25-05-17, 10:05 AM
OC3D Elite
Very nice dude and I love the lightsabre scorch marks on the case
__________________
DRAGON'S MIST
  #29
Old 10-07-17, 01:19 PM
ciobanulx's Avatar
Advanced Member
Thanks a lot mate
  #30
Old 10-07-17, 01:20 PM
ciobanulx's Avatar
Advanced Member
Hey guys!
I just want to share the videos of the build as well for those interested.
I did a time-lapse and showcase video and also a case mod summary video!
Hope you guys enjoy them
Thanks for checking it out!
Cheers,
Alex
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
