Go Back   OC3D Forums > [OC3D] Forum Teams > [OC3D] Benchmark Team
Thread Tools Display Modes
  #81
Old 23-01-20, 12:11 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
I got 5500 last night totally bone stock.
__________________
  #82
Old 10-02-20, 08:37 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Quick and dirty 4.30GHz overclock on the 3950X using 1.30v, Going by peak temps I could probably push 4.40GHz and be quite safe and also I'm only running 3200MHz memory, If I had the Ryzen sweetspot of 3600MHz I could maybe push my score even higher.
10057cb, AMD 3950X, 4.30GHz, 3200MHz DDR4, Windows 10 Pro, Dicehunter
__________________
=AMD Ryzen 9 - 3950X @ 4.20GHz - AMD RX 5700XT @ 2100/1800=
  #83
Old 10-02-20, 08:55 PM
WYP's Avatar
WYP WYP is offline
News Guru
Sees thread.
Thinks - "When did I last update this thread?"
Looks at thread - "oh no"
I guess I need to update this thread...
__________________
_______________________________
Twitter - @WYP_PC
  #84
Old 10-02-20, 08:57 PM
Dicehunter's Avatar
Resident Newb
Originally Posted by WYP View Post
Sees thread.
It's a sparsely used thread so it's not a biggie
__________________
  #85
Old 10-02-20, 09:07 PM
WYP's Avatar
WYP WYP is offline
News Guru
Yeah, but a lack of updates does discourage participation.
I need to get TTL to run one of the new Threadrippers and ruin the charts.
It didn't take long to update. Some of the newer posts either lack a screenshot or don't list their results using the correct notation.
Example (from Ofan):
535cb, Intel i9-9900K, 5.1Ghz, 3333MHz DDR4, Windows 10, Ofan
__________________
Twitter - @WYP_PC
  #86
Old 11-02-20, 02:47 PM
notcool notcool is offline
Advanced Member
Single-threaded:
239cb, i7 920, 3.8GHz, 1600MHz DDR3, Windows 7, notcool
Multi-threaded
1263cb, i7 920, 3.8GHz, 1600MHz DDR3, Windows 7, notcool
Click image for larger version
ID:	12701   Click image for larger version
__________________
i7 920 @ 3.8 / GTX 960 / 12GB RAM / 240GB & 120GB SSDs / 2TB WD Black
  #87
Old 11-02-20, 11:19 PM
WYP's Avatar
WYP WYP is offline
News Guru
Charts updated. I think this may be our first Windows 7 result.
__________________
Twitter - @WYP_PC
  #88
Old 16-04-20, 09:37 PM
D.A.M IT! D.A.M IT! is offline
Newbie
Thought i'd take the new rig for a little spin on cinebench
Multi-Threaded
19344cb, Threadripper 3970X, 4.425, 2133MHz DDR4, Windows 10, D.A.M IT!
  #89
Old 16-04-20, 11:34 PM
WYP's Avatar
WYP WYP is offline
News Guru
Scoreboard updated. It was only a matter of time before somebody threw a Threadripper in there.
__________________
Twitter - @WYP_PC
  #90
Old 17-04-20, 12:54 PM
tgrech tgrech is offline
OC3D Elite
D.A.M IT! that thing would still demolish the table at base clocks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
