Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section > Drivers
Thread Tools Display Modes
  #21
Old 11-10-12, 10:42 PM
marcus1987 marcus1987 is offline
Member
Originally Posted by pexon View Post
i was going to say, i used to plug my old xbox controller in my pc to fly heli's in bf3 no issues, it just plugged and played.
so u lot what the problem is then
  #22
Old 11-10-12, 11:38 PM
Josh Weston Josh Weston is offline
OC3D Elite
Do you have V-Sync enabled? I've had some experiences with V-Sync, especially on Portal 2, in which there's been some god awful input lag. May be worth checking your settings
  #23
Old 12-10-12, 07:04 AM
dugdiamond's Avatar
dugdiamond dugdiamond is offline
OC3D Elite
please post your system specs.
we may be able to help you further, with a little more insight into the PC you are using
__________________
Prepare for the worst. Assume losing. Then... if the opposite occurs... BONUS!
  #24
Old 12-10-12, 11:11 AM
tinytomlogan's Avatar
The Guvnor
Make sure your ram settings are manually added in the BIOS, it can cause similar problems if they are running -auto-
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #25
Old 18-10-12, 09:49 AM
Member
hi thanks i just looked but i cant find where i would do this thanks again please try and help if you can
  #26
Old 18-10-12, 12:26 PM
Terrifictez85 Terrifictez85 is offline
OC3D Elite
I use the software from Joystix when i use my controller on MW3.
Works flawlessly pal
  #27
Old 18-10-12, 09:59 PM
Member
where did u download it from mate
  #28
Old 19-10-12, 11:28 AM
OC3D Elite
Search for Joystix pro in yahoo or google and it is there. Is free, just need to sign up
  #29
Old 19-10-12, 12:32 PM
Member
could u link me please mate
  #30
Old 19-10-12, 12:39 PM
jamesriley94 jamesriley94 is offline
OC3D Elite
Seriously?
Just google it, it's the first thing that comes up!
It really isn't too difficult.
The second link is direct to the specific MW3 one too...
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
