Thread Tools Display Modes
  #11
Old 12-09-17, 07:45 PM
MT. Mods MT. Mods is offline
Member
time to get some work done.
After removing the engine, i had space to start working on the motherboard plate.
So i measured, cut to size, drilled little holes for the standoffs, and then drilled holes in the quad chassis, to secure the tray.
Got bored waiting for the paint to dry haha
Once the paint was dry, i screwed it all down, and it's not perfect, but not supposed to be, it's completely hidden
Now that it's fitted, i added the MB, and secured that down.
Perfect fit, Literally no spare space lol
Will update more as i go.
Thanks for looking
-Craig
  #12
Old 14-09-17, 05:02 PM
Member
Cablemod cables and lights have arrived.
Already started to train the cables into position.
Amazing quality and service as always! Thanks guys
And how they look in the system!
Also added the logo's from our partners (Looks way better)
Thanks for looking
-Craig
  #13
Old 16-09-17, 07:10 PM
Member
While waiting for the Thermaltake goodies, i got to work on some of the details.
Like this!
I used to have a motorbike, always kept my helmets, this was an old one, So.. I cleaned it down.
I then sprayed the whole helmet black, and temporarily fitted 2 6w speakers inside the helmet (Will later affix these properly)
Video here:
I personally think the helmet adds so much to the build, Just need to decided exactly where i want to put it, front of the seat or back.
-Craig
  #14
Old 16-09-17, 10:05 PM
Bartacus Bartacus is online now
OC3D Elite
Awesome stuff Craig, loving this build!
__________________
Guts: Ryzen R7 1700 / Asus CH6 Hero / 16GB G.Skill 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Intel 600p 1TB NVME / 6TB RAID0 array / 2TB RAID0 array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 1 240 rad / Singularity Computers reservoir / dual D5 pumps
  #15
Old 17-09-17, 11:17 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Is the helmet bluetooth? I think it would work much better if it is. Surely you can buy a reasonably cheap bluetooth speaker and cannibalise it?
__________________
He used to do surgery
For girls in the eighties
But gravity always wins
Who do you think you are? running 'round leaving scars. Collecting your jar of hearts, tearing love apart. You're gonna catch a cold, from the ice inside your soul, so don't come back for me, don't come back at all.
  #16
Old 17-09-17, 03:24 PM
Member
Haha, it's not.
I do have a couple of beat pills upstairs, but the problem would be connecting it every time the system starts up, and then you gotta power on the speakers every time.
At least with these, i can just wire them to the main power cable, and both pc and speakers power up at the same time
  #17
Old 17-09-17, 05:55 PM
Member
Back to work on the helmet/Sound
Sprayed the visor black
And started to cable manage the 3.5mm jack cable and power cable.
vinyl wrapped the side vents, and cut the project name and my name, stuck on the visor.
Overall, it adds some really nice aesthetics to the project.
What do you think ?
-Craig
  #18
Old 25-09-17, 06:57 PM
Member
Watercooling is almost all here, just waiting for the CPU block now.
Here's some snaps!
Fittings
GPU blocks
Fans!
PSU
PUMP
Reservoirs
Bending kit (Please note, this ain't no cheap crap barrow kit, this is brushed aluminium with some serious weight)
So far i've only played around with some stuff and can say this... Holy ! lol
The pump looks like it was purposely designed for this quad.
It fits the build so well.
Then the twin reservoirs.... Damnn... this wasn't a planned build, meaning i didn't spenmd hours going over design ideas thinking carefully where to put stuff.. everything has gone on instinct and so far it's gone well.
Some closing images
thank you Thermaltake for this awesome gear, crazy nice too.
-Craig
  #19
Old 12-10-17, 10:49 AM
Member
UPDATE!
CPU block has arrived!
The Thermaltake Pacific W4 PLUS
Mighty fine looking too!
Now we just wait for the radiator, and the quad project will be complete!
Sorry about the delay in updating, it's been a hellish few weeks, multiple projects in the works.
Thanks for looking
-Craig
  #20
Old 12-10-17, 11:37 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Thermaltacky........
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=16gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=Asus ROG Swift=Corsair K95 RGB=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
Tags
crazy, gaming, quad, scratch
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
