Thread Tools Display Modes
  #11
Old 20-08-17, 05:42 PM
Blobby 72 Blobby 72 is offline
Newbie
Update 2.0
This is a low tech build.
The motherboard tray, floor and GPU shelf are all plywood.
Click image for larger version
Notice the pcie ribbon cable and CPU power cut outs.
These were sized up using some old hardware as templates.
The brackets were primed. Then the whole piece painted black.
Now I'm ready for the copper, this inner I frame will be the template for the copper cuts. I'm hoping it is going to be straight. (If it ends up wonky, I'll rename this thread to "Early Access Alpha Build Proper Copper PC")
One copper side started. These will need cleaning up and polishing before I'm ready for solder.
Name:	2017-08-13 22_14_19-picepcATX.skp - SketchUp Make 2017.jpg
Next steps are:
Continue cutting
Cleaning
Polishing
Soldering
Cleaning
Polishing
Lacquering
  #12
Old 20-08-17, 08:19 PM
sheroo's Avatar
sheroo sheroo is offline
OC3D Elite
Lookin' Good!!
__________________
"All his life has he looked away... to the future, to the horizon. Never his mind on where he was."
  #13
Old 21-08-17, 08:52 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Im in curious to see this one through
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=16gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=Asus ROG Swift=Corsair K95 RGB=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #14
Old 21-08-17, 09:02 AM
AlienALX's Avatar
AlienALX AlienALX is online now
OC3D Elite
Interesting so far. Looking forward to seeing it soldered
__________________
He used to do surgery
For girls in the eighties
But gravity always wins
Who do you think you are? running 'round leaving scars. Collecting your jar of hearts, tearing love apart. You're gonna catch a cold, from the ice inside your soul, so don't come back for me, don't come back at all.
  #15
Old 21-08-17, 10:10 AM
Newbie
As am I. I'm hoping it comes out looking clean and, more importantly, not leaking!
Hoping to solder next weekend.
  #16
Old 21-08-17, 12:04 PM
Newbie
A quick explanation
Essenially I am using a short length of 15mm copper, as a barb for the soft tubing.
It's tighter on the soft tubing then most barbs. I could add a clamp but would prefer without.
This piece desperately needs cleaning. And my photography skills need some work.
  #17
Old 24-08-17, 09:04 PM
Newbie
Copper
All cut. Ready for solder
Cleans up pretty well too.
Tags
copper, custom, pipe, water, water cooled
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
