Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
  #1
Old 19-03-21, 02:30 PM
WYP's Avatar
WYP WYP is offline
News Guru
ASUS ROG Strix XG43UQ 4K 144Hz HDMI 2.1 Gaming Monitor is now available to pre-order
A monitor that's designed for high refresh rate PC and console gaming.
Read more about ASUS ROG Strix XG43UQ 4K 144Hz HDMI 2.1 Gaming Monitor becoming available to pre-order.
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 19-03-21, 05:02 PM
AMD Enthusiast
Would prefer a little smaller. 43" is just to big for PC gaming. Although not for console players generally. Though still a great spec sheet. Would be interesting to see if they got rid of the black smear VAs are known for. Samsung Odyssey line is a perfect example of excellent VA panels.
Personally to avoid chroma subsampling, I'd run this over DP using 120hz. Though if you want proper hdr you'll need to drop down to 98hz. This is if you don't have a hdmi 2.1 card since 95% of the people who want one don't have access to getting one.
  #3
Old 19-03-21, 08:39 PM
WYP's Avatar
WYP WYP is offline
News Guru
This uses DisplayPort 1.4 with DSC. So 4K at 144Hz can be used without chroma sub sampling.
__________________
Twitter - @WYP_PC
  #4
Old 19-03-21, 09:56 PM
Bartacus Bartacus is offline
OC3D Elite
I have a 43" ultrawide, and you do need to sit back a bit, but it doesn't feel as big in front of you as specs would have you believe. But if I had a do-over, I would drop back to a 35" for sure. Some of us nerds need to get our impulse buying under control!
__________________
Games: Ryzen 5950X on GB Aorus Master X570 / Asus TUF 6900XT / 32GB TridentZ Neo 3600CL16 (16GB x 2) / custom loop
Workstation: Threadripper 2950x on GB Aorus Xtreme X399 / Zotac 2080ti / 32GB TridentZ 3200CL14 (8GB x 4) / custom loop
Home Theatre: Ryzen 3900X on Asus C7H X470 / Radeon VII / 16GB G.Skill 3600CL15 (8GB x 2)
/ custom loop
  #5
Old 19-03-21, 09:59 PM
AMD Enthusiast
Yes avoid compression entirely. That was my point. By using DSC and then using HDR and 10bpc(assuming it supports this) kind of defeats the purpose of those features. You are just losing quality at that point. And while normally you wouldn't notice, being 43" the pixel density is low and you're sitting close if you are on PC. You'd notice the smudged pixel sections outside of super fast paced games.
If it was 27/32"? Wouldn't be an issue I think.
  #6
Old 19-03-21, 10:46 PM
Kroma Kroma is offline
Newbie
Bigger the better!
  #7
Old 20-03-21, 06:23 AM
looz's Avatar
looz looz is offline
OC3D Elite
I'll make the same bet here as with the CD quality sound - while technically better quality exists, you won't be able to tell the difference between DSC on vs. DSC off.
__________________
i7 9900k - 16GB - 3080 XC3 Ultra - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
  #8
Old 20-03-21, 04:22 PM
Warchild Warchild is offline
OC3D Elite
I did see a difference on the Odyssey G7 which uses DSC. Minor, but it was there. Nothing worth kicking up a fuss over though so I guess its how picky people are. Some probably get frustrated by it more than others.
  #9
Old 20-03-21, 04:46 PM
AMD Enthusiast
Assuming you had the 27" but then imagine how much worse it would be in this 43" monitor that has less pixel density. It would be even more noticeable as the pixels would appear larger which makes the lossy compression conversion easier to spot.
Nice to hear from someone who actually uses it though.
Best solution is hdmi 2.1 but not everyone has a card with that yet.
  #10
Old 22-03-21, 08:46 AM
OC3D Elite
Correct, it was the 27" but you are right, I guess for that 43" it would be far more noticeable.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
