Go Back   OC3D Forums > [OC3D] Customer Care Forums > MSI UK Forum
Thread Tools Display Modes
  #1
Old 24-05-18, 08:10 PM
shambles1980's Avatar
shambles1980 shambles1980 is offline
OC3D Elite
780 ti twin frozor "Probably in the wrong section"
Heyo,
I doubt il get an official from msi answer here but perhaps some one else can tell me??
Just received a MSI Twin frozr 780ti in the post. (it was sent broken, i knew it was broken, its not DOA it was known Dead before being sent) no waranty no rma none of that..
now the issue is "at the very least" the Apw7142 IC is blown. And i cant read the bottom row of text because there is a nice little blown out burnt spot on that."
It looks a lot like it ends with 83 and possibly started ap.
But i cannot find any apw7142's that end with 83.
So if any one knows what the full part number of the ic is that would help. failing that i would just need to know if the input/output voltages and amps are all the same on every diferent revision as the data sheet does not specify differences..
thanks for the time.
And feel free to move the thread if you know where it should be.
__________________
i7 2600, intel dz77sl-50k, 16gb 1600 DDR3, 900d case, gtx 780 @ 1306/1727 "xspc block", 1x 240 1x360 1x480 rads 2 bay res, http://www.3dmark.com/3dm/14829772
  #2
Old 25-05-18, 10:17 AM
Kei's Avatar
Kei Kei is offline
OC3D Crew
That second row of text is just a 5 character date code. The full name of the part is apw7142ki-trl or apw7142ki-trg. The only variations are in the last letter of the name where L : Lead Free Device and G : Halogen and Lead Free Device. It's a 12V 3A Synchronous-Rectified in SOP-8 package.
Datasheet available here.
__________________
Gigabyte Aorus X399 Gaming 7 ⁞⁞ Ryzen TR 1920x ⁞⁞ EK Blocks + αcool XT45 rads ⁞⁞ AMD Radeon Vega 56 ⁞⁞ 32GB 8 Pack 3200C14 ⁞⁞ Enthoo Primo
Seasonic Prime 750W ⁞⁞ Polaris 961 256GB ⁞⁞ 850 Pro 512GB ⁞⁞ M500 240GB ⁞⁞ WD Se 4TB & 1TB x2 ⁞⁞ Samsung C27HG70 + Dell 2408WFP
Ducky Shine 5 ⁞⁞ AJA Kona LSe ⁞⁞ RME HDSPe AIO ⁞⁞ Marantz AV7701 ⁞⁞ Tannoy SRM 10B ⁞⁞ AKG K601 ⁞⁞ Beyer DT770
  #3
Old 25-05-18, 02:55 PM
OC3D Elite
cheers now i just need to wait for one to arrive before i can see what else is probably dead too.
p.s
if any one was wondering the guy said the psu and gpu died at the same time, so i assume the psu took out the gpu.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
