Go Back   OC3D Forums > [OC3D] General Forums > OC3D Reviews & Videos
Thread Tools Display Modes
  #21
Old 06-07-17, 02:24 PM
Gothmoth Gothmoth is offline
Member
Originally Posted by AngryGoldfish View Post
SPD is the default memory speed for Ryzen as a platform. 2133Mhz is guaranteed to work with all RAM that is rated for that speed. DOCP is essentially the same as Intel's XMP profile. It is the overclocked frequency the RAM is rated for.
i still don´t understand why they say in that list the RAM is certified for 3000 MHz and under DOCP it is listed as 2666.
for me it would be logical that a 3000 MHz certified memory is listed as 3000 DOCP.... not 2666.
lets take the first RAM in the list as example, the corsair.
it´ a 3000 MHz branded RAM, so it should OC to 3000 MHz.
it is certified as 3000 MHz in the asus QVL.. but the DOCP says 2666.... you see why i am confused?
ps:
to be honest this RAM stuff is holding my purchase off.
i just want to run 2x16GB at 3000 or better 3200 and nobody, not asus or g.skill (i wrote emails to both) can tell me which RAM i should buy ("we can give no official recommendation" - g.skill. we are working on supporting more memory. the QVL will be updates in the future. - asus").
when the motherboard and RAM maker can not give a recommendation... than who can?
i guess building a ryzen system is stil a lot of try and error when it comes to memory.
and maybe i let the platform mature a few more month.
  #22
Old 06-07-17, 04:46 PM
AngryGoldfish's Avatar
AngryGoldfish AngryGoldfish is offline
Old N Gold
ps:
I hear your pain, man. It's really a shame. Either you have to compromise or you have to take a risk.
2666Mhz might be a guaranteed overclock for Ryzen while 3000Mhz is what the kit should hit if all other factors came together. Maybe 2666Mhz is rated for Ryzen while 3000Mhz is the kit's rated speed on a system that supported it fully, such as Z270.
You could always buy a 2x16GB kit that is rated for 3000Mhz and if it doesn't run it at that speed, knock it down until it does. Then when the BIOS' have improved you could increase the A-XMP to 3000Mhz. That's what the majority of people are doing.
__________________
ASUS X370 Crosshair VI Hero ⁞⁞ Ryzen 1600X 4Ghz ⁞⁞ Thermalright Le Grand Macho RT ⁞⁞ Aorus GTX 1080 11Gbps ⁞⁞ G.Skill TridentZ 3200Mhz
Jonsbo W2 ⁞⁞ Corsair AX760 ⁞⁞ Pexon PC ⁞⁞ Samsung 960 EVO 250GB & 850 EVO 500GB
⁞⁞ Western Digital 1TB Blue & 3TB Green
BenQ XL2730Z ⁞⁞ Mixonix Naos 7000 ⁞⁞ Corsair K70 Cherry MX Brown ⁞⁞ Audio-GD NFB-15 ⁞⁞ EVE SC205 ⁞⁞ AKG K7XX
  #23
Old 07-07-17, 02:20 PM
Member
someone from g.skill got back to me and told me that the SPD/DOCP column tells me what speed can be automatically set for the RAM by the bios. so even when RAM is certified for 3000 MHz i need to put in manual settings when under SPD/DOCP only 2133 or 2666 MHz is listed. with the DOCP setting alone, i would only achieve 2133 or 2666 MHz.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
