Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #1
Old 27-03-20, 10:51 AM
WYP's Avatar
WYP WYP is offline
News Guru
This 3D Printed Case brings DIY NAS building to a new level
Meet the 3Dwebe MK735, the ultimate DIY NAS case.
Read more about the 3Dwebe MK735 DIY NAS Chassis.
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 27-03-20, 11:56 AM
Warchild Warchild is offline
OC3D Elite
I see a number of us have 3D printers now. We should make a thread and share things we created, remixed or downloaded.
Might be something you created of use to me and vice versa. Or present ideas.
I'm working on some mods for the 1000D at the moment.
This case though is really impressive. I like the possibilities.
  #3
Old 27-03-20, 12:45 PM
WYP's Avatar
WYP WYP is offline
News Guru
That's a great idea. we should start that. I wanted to build this, but my printer isn't wide enough. Needs an extra 2cm..
__________________
Twitter - @WYP_PC
  #4
Old 27-03-20, 02:19 PM
OC3D Elite
There was talk about mods to extend and ender 3 printing diameter. Or perhaps it was a new extruder... let me try to find it for you.
Lately ive been making someone very happy by printing some pokemon that are hard to get. Also had to make a spool holder for my 3kg PLA... underestmated the size of the spool. Made on on rollers for it.
  #5
Old 27-03-20, 02:59 PM
WYP's Avatar
WYP WYP is offline
News Guru
At stock the base is 220mm x 220mm, but the base actually supports 235mmx235mm if you upgrade the firmware. Still not large enough.
Yeah, 1KG of PLA can last for ages. I have three KG spools and I haven't used one yet. That said, I have been using all three colours.
I still need to start those PC mods that I have planned. Making some D&D models to test slicer settings ATM.
__________________
Twitter - @WYP_PC
  #6
Old 27-03-20, 03:53 PM
OC3D Elite
Which slicer do you use?
I tried the creality slicer but found it was no comparison compared to ultimaker cura, really liked the way tyou can auto create supports and even change infill patterns on that one.
  #7
Old 27-03-20, 05:12 PM
WYP's Avatar
WYP WYP is offline
News Guru
I started with Cura. I've found it to be very versatile. Have been making some 3D miniatures for D&D lately as a test. Supports can be challenging.
__________________
Twitter - @WYP_PC
  #8
Old 28-03-20, 10:49 AM
OC3D Elite
Ultimaker cura is very good at generating supports though if you set it to touching bed, and then look at the preview
  #9
Old 28-03-20, 10:51 AM
WYP's Avatar
WYP WYP is offline
News Guru
It's just that they are hard to remove sometimes and it that it sometimes doesn't generate supports where you need it. You need to be careful when making minis.
__________________
Twitter - @WYP_PC
  #10
Old 28-03-20, 11:57 PM
Bartacus Bartacus is offline
OC3D Elite
You need to look into the Ender Extender. https://enderextender.com/
Assuming you could get one nowadays, it looks to be a sweet piece of kit.
__________________
Guts: ThreadRipper 2950X / GB Aorus Xtreme X399 / 64GB TridentZ Royal 3600CL16 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU
Storage: 6TB RAID0 NVME array (ADATA SX8200 Pro 2TB x 3)
Water Cooling: HeatKiller TR4-Pro CPU block / HeatKiller IV GPU blocks / 360mm Darskide LP360 rads x 3 / Heatkiller reservoir
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
