Go Back   OC3D Forums > [OC3D] Cooling Forum > Cooling - Other
Thread Tools Display Modes
  #1
Old 31-10-16, 08:50 AM
steverebo's Avatar
steverebo steverebo is offline
OC3D Elite
Liquid metal TIM on GPU?
Ok Im chasing lower temps and silence on my system as my gtx 1080 FE starts to throttle at 45 degrees. Ive been looking for tge best TIM and its always the coolab liquid ultra. Both my blocks are nickel plated copper so there should be no reaction.
Is it safe to use liquid metal TIM on your gpu die?
Dont want to kill my £700 GPU
__________________
BeQuiet Darkbase Pro 900 | i7-7700K OC @ 5.10GHz | Custom water loop | ASUS MAximus Hero IX Z270 | Aurous Xtreme GTX 1080TI @ 2120mhz 12000mhz | 16GB Corsair Dominator Platinum @ 3200MHz CL15 | 500GB Samsung 960 Evo, 250GB Samsung EVO 850 | Corsair HX750I PSU | Windows 10 Pro 64-bit
  #2
Old 31-10-16, 08:53 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Put an AIO on it dude.
__________________
  #3
Old 31-10-16, 09:24 AM
tolagarf's Avatar
tolagarf tolagarf is offline
OC3D Crew
Nevermind. Seems I need to learn and read
Edit: So your watercooled cards throttle at 45C? Then something is clearly wrong as they shouldn't throttle before they reach about 83C. You sure this isn't g-sync down volting the card?
  #4
Old 31-10-16, 09:26 AM
Warchild Warchild is offline
OC3D Elite
Yes its safe. I have done it for years with good results. Just remember that you have to use a VERY small amount and spread it. The layer you put on there should incredibly thin, and also make sure none of the TIM spreads anywhere other than the surface of the die.
Check out coollaboratory how they do it. Although personally I dont like using a cotton bud. I prefer a flat spatula.
My idle temps are around 19C and fully loaded top out at 39C on both 980Tis. I think I had better results on my 780s though.
  #5
Old 31-10-16, 09:29 AM
steverebo's Avatar
OC3D Elite
I didnt know gsync could downvolt the card??
From what ive read its pretty normal for gpu boost 3.0 my card is clocked at 2038 and will drop down to 2025 and then 2012 as the temp increases.
Thats perfect cheers warchild. Im only chasing 2 or 3 degrees to keep the overclock at the level I want whilst maintaining system silence. I was considering push pull on my ut60 but will try this first before spending another £75 on fans
__________________
  #6
Old 31-10-16, 09:32 AM
AlienALX's Avatar
OC3D Elite
Ah I see. Don't put an AIO on it
I can't see why not. If people use it on a delidded CPU then a GPU core would be absolutely no different. I mean, it's a piece of silicon.
__________________
  #7
Old 31-10-16, 09:37 AM
tolagarf's Avatar
OC3D Crew
Indeed it does that even for my air cooled 1080 FE. Start off by 1835 MHz and then drops down to 1795 or something over time. But sometimes it can drop below stock clock, and this happens when the card isn't being taxed very hard by a game, that just can't torture the card which is usually caused by g-sync.
But I'm just not seeing it as very important. I won't feel the difference anyway.
  #8
Old 31-10-16, 09:47 AM
OC3D Elite
I really don't see the point in a push pull configuration since there is only between 1 and 3 degrees difference, and added noise. I'd prefer swapping a 360 with a 480 rad myself with more watt dissipation from higher surface area. Thats just 1 extra fan as opposed to an extra 3 in push pull. If you cant fit a 480, then I would stick with the push config.
Also depending on your card. Liquid TIM could drop your temp by up to 7 or 8 degrees if you are lucky.
As for your clock behaviour, I have nothing to add because I have no experience with GPU 3.0. I thought you could unlink the temp limit and power limit values and set them all to max?
  #9
Old 31-10-16, 10:28 AM
steverebo's Avatar
OC3D Elite
No space for bigger rads unfortunatley Ive squeezed all I can i to my heavily modded H440 although I am thinking of changing to a 780t or enthoo primo in the future.
You can ulink everything and max it out which I have done but these drops are part of the pascal architechture its very funny when it cones to temps and core speed. If i crank my fans up it never drops as my gpu will sit between 38 and 40 degrees full load but that comes with increase in noise.
Im trying to get the best of both worlds silent but powerfull!
My system is currently quieter whilst gaming than my sons xbox one
__________________
  #10
Old 31-10-16, 10:30 AM
AlienALX's Avatar
OC3D Elite
LMK how you get on Steve. I might give this a go myself
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
