Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 07-11-15, 03:36 PM
litwicki24 litwicki24 is offline
Banned
High cpu temp on stock cooling 4790k
Hello. I have 4790K with stock cooler. During Black Ops 3 my cpu temps are 90-100c. I think i mounted good cooler.
Is this normal for stock cooler or not? Black Ops 3 only giving that high temps.
Cpu is on turbo clock 4 ghz - 4,2 ghz. And on 4,2 ghz i have 90c+ sometimes it will spike to 100c during each places in game.
  #2
Old 07-11-15, 03:42 PM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
Everyone will tell you the same thing don't use the stock coolers fella get an aftermarket
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
  #3
Old 07-11-15, 03:47 PM
shambles1980's Avatar
shambles1980 shambles1980 is offline
OC3D Elite
sounds pretty hot even for stock.. do you have correct contact and thermal paste?
__________________
i7 2600, intel dz77sl-50k, 16gb 1600 DDR3, 900d case, gtx 780 @ 1306/1727 "xspc block", 1x 240 1x360 1x480 rads 2 bay res, http://www.3dmark.com/3dm/14829772
  #4
Old 07-11-15, 03:48 PM
barnsley's Avatar
barnsley barnsley is offline
born in a.....
Its probably not mounted correctly or the fan isn't getting the signal to increase in speed. Is the computer loud?
__________________
Rig: i7 [email protected]|2x8gb HyperX Fury|Intel z97-AR|Corsair H75| 2x Nvidia 1070 founders edition|Superflower leadex 750W gold|Inwin 904| 970 EVO 500GB m.2|512GB evo 840| Crucial MX 500 500GB|ASUS MG279Q +Acer S240HL| Windows 10 pro, 8.1 pro| Kubuntu LTS
Audio: Silverstone EB01-E+EB03+DT 770 Pro 250Ω+Samson SAGOMIC
Ducky Legend (cherry red)+Zowie AM-FG
  #5
Old 07-11-15, 03:52 PM
Banned
Cpu is loud yes. I think i mounted cooler ok. Paste is applied on stock to cooler.
Only Black Ops 3 giving me that temperatures.
When cpu is on 4,2ghz on auto, then i have 90+C sometimes it will spike to 100C.
  #6
Old 07-11-15, 03:55 PM
OC3D Elite
i would try to remount, and double check that its being mounted correctly..
__________________
  #7
Old 07-11-15, 05:00 PM
Pr3d4t0r Pr3d4t0r is offline
OC3D Elite
Im sure everyone here will tell you to get a better cooler first thing :P its not that expensive and its a massive difference.
we can go through some stupid stuff like did you peel plastic off of cooler before applying etc. but its 99% the fault of stock cooler that isn't adequate to run 4790k especially at 4hgz+ oc
__________________
[email protected], PowerColor Red Devil 5700xt ,16GB TeamGroup 2600mhz/cl9, Corsair HX850i, NZXT H440 grid+, Corsair H100
  #8
Old 07-11-15, 05:03 PM
Banned
Cooler is seated properly. Because on other games i have temps 80C+. Weird because only Black Ops 3 giving me 90C+ ( sometimes 100C ,depending on load cpu ).And i dont know why.
  #9
Old 07-11-15, 05:04 PM
OC3D Elite
80c+ seems hot to me..
Edit:
If you are over clocked then yes you need a better heat sink. if its just the turbo boost then the stock solution should be barely adequate.
(i would be trying to keep the temps at about 75-78c whilst heavy gaming. anything higher than that and i would not be happy.)
__________________
  #10
Old 07-11-15, 05:07 PM
DarthDudo's Avatar
DarthDudo DarthDudo is offline
Advanced Member
You mentioned it is set to Auto, what voltage is being applied to the CPU?
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
