Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #1
Old 20-10-20, 10:04 AM
WYP's Avatar
WYP WYP is offline
News Guru
AMD Radeon RX 6000 series Power Consumption and Memory Specs Leak
Navi 21 XT is a beast.
Read more about AMD's Radeon RX 6000 series power consumption and memory specs.
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 20-10-20, 10:56 AM
AngryGoldfish's Avatar
AngryGoldfish AngryGoldfish is offline
Old N Gold
That initial power rating did seem a bit too good to be true. And it would seem unnecessary to invest in a large cooler for a 220-250W card when a more compact (and cheaper) two-slot dual fan design would have been adequate, as the Power Color Dragon 5700 XT testifies to.
It's looking more and more likely that AMD's top tier card from AIB partners will surpass a 3080, at least in some titles.
__________________
ASUS X370 Crosshair VI Hero ⁞⁞ Ryzen 1600X 4Ghz ⁞⁞ Thermalright Le Grand Macho RT ⁞⁞ Aorus GTX 1080 11Gbps ⁞⁞ G.Skill TridentZ 3200Mhz
Jonsbo W2 ⁞⁞ Corsair AX760 ⁞⁞ Pexon PC ⁞⁞ Samsung 960 EVO 250GB & 850 EVO 500GB
⁞⁞ Western Digital 1TB Blue & 3TB Green
BenQ XL2730Z ⁞⁞ Mixonix Naos 7000 ⁞⁞ Corsair K70 Cherry MX Brown ⁞⁞ Audio-GD NFB-15 ⁞⁞ EVE SC205 ⁞⁞ AKG K7XX
  #3
Old 20-10-20, 12:17 PM
lokinmodar lokinmodar is offline
Newbie
Why not GDDR6X?
  #4
Old 20-10-20, 12:23 PM
tgrech tgrech is offline
OC3D Elite
Originally Posted by lokinmodar View Post
Why not GDDR6X?
It would currently half their possible memory capacity(Without huge expensive PCBs), and cost more ofc, when one of Navi2's key competitive points seems to be its ability to reduce end cost by requiring lower memory bus bit widths(And also therefore fewer memory chips) to achieve a given effective bandwidth.
Would make more sense when manufacturers have 16Gb/2GB GDDR6X chips ready, but whether or not it will deliver enough gains for them tto consider the cost worthwhile for a refresh or something is still to be found out I guess.
  #5
Old 20-10-20, 03:32 PM
Old N Gold
Also, Nvidia is said to have bought all the GDDR6X stock.
__________________
  #6
Old 20-10-20, 04:01 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
I don't think GDDR6X is necessary on a gaming card.
The 20 series does fine without it. It would just jack costs up even more and jack up the power use too.
Also I have a feeling that once again this should have been a low wattage card, but due to Nvidia's pre emptive strike and known performance AMD have cranked on the card again. Which they probably would have done regardless, as no one leaves anything in the tank now.
Hopefully they will be easier to get blocks for.
__________________
If you don't like what I post don't read it.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
