Reccomnedation for iCUE
Hi Corsair, I have had a few failures over the past year on my H115i pump.
It would be good if you can put an alert in iCue software to detect abnormal pump speed. My last pump was running over 3000rpm when I noticed that it failed.
I only noticed because my PC started to randomly crash with WHEA BSOD's when under load.
Now after checking with various sources and on my brand new replacement the pump speed should be around 2850rpm under extreme profile and around 1860rpm under the quiet profile give or take 100rpm, so it would be quite easy for you to implement this alert when the pump is running abnormaly.
Regards, FTLN
__________________
Intel Core i9 7980xe @ 4.5GHz @1.18v - MSI MEG X299 - NoName 2666mhz @ CL19 3200mhz - Thermal Take View Glass - PM961 1TB x2 - Aorous Extreme RTX 2080 Ti - 2 x 360 Rad + D5 Pump - Asus ROG Swift PG279Q 2560x1440P G-Sync 165Hz
