Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #1
Old 03-04-20, 01:15 PM
WYP's Avatar
WYP WYP is offline
News Guru
Zen 3 reportedly contains a hefty single-threaded IPC boost and higher clock speeds
AMD's targetting Intel's single-threaded performance.
Read more about Zen 3's rumoured single-threaded IPC boost.
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 03-04-20, 02:03 PM
Gambit2K Gambit2K is offline
Newbie
Thumbs down
10-15% is "hefty"?
  #3
Old 03-04-20, 02:07 PM
WYP's Avatar
WYP WYP is offline
News Guru
Originally Posted by Gambit2K View Post
10-15% is "hefty"?
When combined with clock speed boosts it is. Also, have you seen Intel's past 4 years of IPC increases?
__________________
Twitter - @WYP_PC
  #4
Old 03-04-20, 02:11 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
10-15% is "hefty"?
It is for a refresh yes.
__________________
  #5
Old 03-04-20, 03:21 PM
Newbie
It's not refresh, AMD has multiple times said it is a new architecture. Zen 4 will be built upon the Zen 3 architecture, so Zen 4 will more be a refresh than Zen 3 will be.
AMD has also said that the Zen 3 will be as big of a step as Zen--> Zen 2 was, NOT Zen -->Zen+. So a 10-15% IPC increase is small (A frequency bump is not counted towards the IPC increase).
  #6
Old 03-04-20, 03:29 PM
tgrech tgrech is offline
OC3D Elite
Zen 2's IPC gains were 5-15% over Zen1 depending on workload. In contrast, the last Intel IPC gains on a mainstream desktop platform were in 2015 and were in the region of 2-5%, as was the one before that.
Almost all of Zen+'s gains over Zen1 were clock speed(Some v small gains from cache/uncore tweaks), any other gains Intel has made since then are clock speed, the rest of Zen2's gains over Zen+ besides that 5-15% were clock speed, IPC gains at all seem to be a rare treat nowadays.
  #7
Old 03-04-20, 03:48 PM
AngryGoldfish's Avatar
AngryGoldfish AngryGoldfish is offline
Old N Gold
Both AdoredTV and The Good Old Gamer were claiming 20% as a low-ball estimate in terms of IPC, and then a clock speed boost on top of that. They based this off of their interpretation of an interview with an AMD staff member. They seemed convinced. I think that's why a 10-15% IPC boost seems disappointing to them, because it's less than what they had decided in their heads Zen 3 would be.
Personally I'd say that 15% alongside a boost in clock speeds is excellent, especially when you consider the latency reduction Zen 3 is supposed to introduce. That would put AMD ahead of Intel in terms IPC as well as TDP and core count, all with higher income per unit sold. And their latency numbers would be comparable too. Zen 4 would expand on that. Even if Intel massively boosted their performance by 2021, AMD should be able to match them. And even if Intel sneaks ahead again, it'll only be in certain areas. AMD has garnered so many new fans and has developed such a cost-effective infrastructure that it may not matter if Intel are ahead in certain areas.
__________________
ASUS X370 Crosshair VI Hero ⁞⁞ Ryzen 1600X 4Ghz ⁞⁞ Thermalright Le Grand Macho RT ⁞⁞ Aorus GTX 1080 11Gbps ⁞⁞ G.Skill TridentZ 3200Mhz
Jonsbo W2 ⁞⁞ Corsair AX760 ⁞⁞ Pexon PC ⁞⁞ Samsung 960 EVO 250GB & 850 EVO 500GB
⁞⁞ Western Digital 1TB Blue & 3TB Green
BenQ XL2730Z ⁞⁞ Mixonix Naos 7000 ⁞⁞ Corsair K70 Cherry MX Brown ⁞⁞ Audio-GD NFB-15 ⁞⁞ EVE SC205 ⁞⁞ AKG K7XX
  #8
Old 03-04-20, 03:55 PM
AlienALX's Avatar
OC3D Elite
AMD don't need more IPC. It's not IPC keeping them from winning everything, it's clock speed. Getting down to the nm they are on they can fit lots of cores under a small die. Now comes time to get the clocks up to match Intel.
However, IPC is nice. It's not that keeping them from winning the gaming crown though, IMO.
Some games still get off on very high clocks.
That said, 15% as noted is way better than Intel have managed in an absolute age. So why not?
__________________
  #9
Old 03-04-20, 04:03 PM
AMD Enthusiast
Think you need to come back to the real world and get your head straight.
  #10
Old 03-04-20, 04:10 PM
OC3D Elite
One thing I will say, this will likely seem like a small gain in comparison to whatever Intel's IPC gains are likely to be from their next desktop architecture, which could be in the 15-25% range, BUT that has to be taken in the context of the fact the last IPC gains for Intel on desktop were with the introduction of Skylake in 2015, half a decade ago, and is likely going to come with at least a few % drop in clocks compared to these >5Ghz highs of 14nm+++.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
