Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #1
Old 24-03-20, 06:16 PM
Eddie long's Avatar
Eddie long Eddie long is offline
Advanced Member
radiator choice/opinions
since i got in to computers and water cooling I've always used EK rads but i was wondering can anyone put there input in fore or against .
i have been looking at alphacool nexXxos v2 as i quite like the look and they are full copper.
thanks
__________________
Life isn't always a bowl of cherry's.
Sometimes it's HARD WORK
  #2
Old 24-03-20, 07:48 PM
Warchild Warchild is offline
OC3D Elite
Black Ice rads are very good.
  #3
Old 24-03-20, 07:54 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Funnily enough Bitspower's new rads are much cheaper than the old ones.
https://www.overclockers.co.uk/bitsp...wc-68h-bp.html
https://www.overclockers.co.uk/bitsp...wc-68g-bp.html
__________________
  #4
Old 24-03-20, 10:01 PM
Eddie long's Avatar
Advanced Member
thanks for the suggestions will do some investigations
__________________
  #5
Old 25-03-20, 01:27 AM
Avet's Avatar
Avet Avet is offline
OC3D Elite
VSG does amazing WC gear reviews at TechPowerup. (used to be on thermalbench.com)
Newest results:
https://www.techpowerup.com/review/c...adiator/5.html
I would recommend HardwareLabs all the way and forever.
__________________
Turbos on an engine is God's way of telling you it ain't got enough cylinders.
  #6
Old 25-03-20, 11:23 AM
Eddie long's Avatar
Advanced Member
Newest results:
thanks for the info , i forgot about the work thermal bench did
__________________
  #7
Old 25-03-20, 12:44 PM
Eddie long's Avatar
Advanced Member
well after much reading and a few suggestions i have ordered a HWlabs black ice gtr , lets hope it lives up to its reviews
__________________
  #8
Old 25-03-20, 01:17 PM
OC3D Elite
It is. Black ice are outstanding.
  #9
Old 21-04-20, 09:15 AM
Ady6UK's Avatar
Ady6UK Ady6UK is offline
Member
__________________
Lian Li O11Dynamic XL black, i7 8700K delidded @ 5ghz, Asrock Z370 Taichi mobo with Bitspower monoblock, 32Gb (4x8Gb) Thermaltake TOUGHRAM Z-ONE RGB Memory DDR4 3600MHz, Seagate Firecuda 1Tb Nvme with M.2 ssd with heatsink, Samsung PM981 1Tb Nvme M.2 ssd with EK heatsink, WD Blue 3D NAND SATA M.2 2Tb with EK heatsink, 3 Tb Toshiba External HDD, EVGA GTX 1080Ti SC2 Black Edition gpu with EK waterblock, Corsair HX750i Platinum PSU, EK FLT 360 D5 pump/res, HW Labs GTS 360 + GTR 360 Rads, Corsair ML 120 pro fans.
  #10
Old 21-04-20, 10:37 AM
Eddie long's Avatar
Advanced Member
Thanks for all the advice .
Well my simple case change and slight upgrade has got carried away with its self
Will post pics when I get started
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
