Go Back   OC3D Forums > [OC3D] Processors & Platforms > Overclocking
Thread Tools Display Modes
  #1
Old 11-02-18, 12:03 PM
SebastianAltena's Avatar
SebastianAltena SebastianAltena is offline
Newbie
Unhappy Intel 4770k BSODs after 7 to 10 h of Scrypt(squared) CPU mining
My 4770k BSODs like a clockwork every 7-10 hours, everything is on auto exempt vCore at 1.080v.
I have tried switching clocks to manual, lowering cpu core and cpu ring multiplier to 35x, increasing cpu voltage to 1.1 and cpu ring to 1.15, I have also tried lowering memory clock from 2400mhz to 1800mhz, nothing changes. Only thing I haven't changed is SA, digital and analog I/O voltages, I don't want to touch them before I fully understand what they do.
I have tried everything I can think of, and I don't get why it crashes.
Crash Dump Analysis provided by OSR Open Systems Resources, Inc. (http://www.osr.com)
Online Crash Dump Analysis Service
See http://www.osronline.com for more information
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.18247.amd64fre.win7sp1_gdr.130828-1532
Machine Name:
Kernel base = 0xfffff800`02815000 PsLoadedModuleList = 0xfffff800`02a586d0
Debug session time: Wed Feb 7 22:39:23.918 2018 (UTC - 5:00)
System Uptime: 0 days 1:52:50.543
* Bugcheck Analysis *
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa800daaa028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000be000000, High order 32-bits of the MCi_STATUS value.
Arg4: 000000000100110a, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
BUGCHECK_STR: 0x124_GenuineIntel
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: cpuminer.exe
CURRENT_IRQL: f
STACK_TEXT:
fffff880`0254ab58 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: GenuineIntel
IMAGE_NAME: GenuineIntel
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_CACHE
Followup: MachineOwner
  #2
Old 11-02-18, 02:17 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Ran a proper memtest? I would start there. Then reseat the RAM etc.
Whoah.. Hang on a minute...
Firstly I would make sure you are not on a website that mines in the background. You can get a plugin to block that. I would then install, and run, a full scan of MalwareBytes anti malware. Your CPU is being mined on, unless that is you doing it.
https://malwaretips.com/blogs/cpu-miner-removal/
Yup you have a trojan ragging the crap out of your PC.
__________________
  #3
Old 11-02-18, 02:39 PM
Newbie
I did ran memtest for 16 h without issues.
I'm running cpu miner when I'm not using my pc, to mine verium reserve, that is the point, I wanna mine overnight but my pc crashes after about 7h.
  #4
Old 11-02-18, 06:14 PM
Avet's Avatar
Avet Avet is offline
OC3D Elite
What are your other components? How good is your cooling? If GPU overheats it can shutdown PC. Older ones did that. I had a problem with MBO chipset overheating on and crashing system. What is your PSU? It may overheat after 7 hours and shut down. Please put your rig specs.
  #5
Old 11-02-18, 07:54 PM
Newbie
cooler: cooler master hyper 212 evo, cpu temp is floating around 60-65 under full load.
Gpu: Asus dc2 gtx770, I'm not mining with gpu, and it works fine in games.
Psu corsair tx650 from 2012, fan doesn't even spin up, it's cold to the touch, pc pulls 150w from wall while mining.
Modbo: msi z87-g45, I don't know how to get vrm and chipset temps.
My pc is generally stable, I gamed on it for over 4h with gpu at full load (uncapped frame rate) and converted 1080 videos for 4 to 5 h without any issues, but my cpu won't overclock to more than 4.0ghz on 1.2V so I kept it at stock.
  #6
Old 11-02-18, 08:59 PM
Avet's Avatar
OC3D Elite
It looks ok. But if you say your CPU isn't a good overclocker it might be that is bad silicon, and something in that mining load is choking it.
  #7
Old 11-02-18, 10:36 PM
Newbie
That would be my guess, I just tried bumping up ring multiplier to 40x and it crashed within minutes with same 124 error code. However lowering cpu ring multiplier to 30x and increasing ring voltage to 1.2 didn't do anything, It's really frustrating.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
