Thread Tools Display Modes
  #61
Old 31-05-20, 09:54 PM
looz's Avatar
looz looz is offline
OC3D Elite
You still need a few more for maximum cooling:
__________________
i7 8700k - 16GB - 2060 FE - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
  #62
Old 31-05-20, 10:11 PM
Avet's Avatar
Avet Avet is offline
OC3D Elite
That is some proper engineering. Well done.
__________________
Turbos on an engine is God's way of telling you it ain't got enough cylinders.
  #63
Old 31-05-20, 10:15 PM
Warchild Warchild is offline
OC3D Elite
Thanks, but I'm really not liking the bulkiness of it all. Testing a complete shrink down now. Hopefully its just as effective and not as blocky. This time instead of using someone elses model, im making my own.
Simplicity all the way!
I'm sure If TTL wanted to donate all those, I would have space in the case to make it all fit . But would need to bolt it down so it doesnt take off.
  #64
Old 01-06-20, 11:49 AM
OC3D Elite
Revision 1 to simplify the idea
Before
After
  #65
Old 01-06-20, 12:27 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
nice printing
__________________
ASUS ROG Crosshair VII wifi | Ryzen 5 3600 | Custom Loop | Patriot Viper Steel 4133 @ 3600 2 x 8Gb | Asus Strix RX 470 | Samsung 500gb nvme | Samsung 1Tb nvme | Samsung Evo 120gb ssd | Seagate Barracuda 1tb storage | Toshiba 1Tb HDD | EVGA 500w | Phanteks Entho Pro Tempered Glass | Windows 10 and Linux Manjaro
  #66
Old 01-06-20, 12:41 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Very cool.
__________________
  #67
Old 01-06-20, 01:44 PM
looz's Avatar
OC3D Elite
Proper good work!
__________________
  #68
Old 02-06-20, 10:18 PM
OC3D Elite
Toying with some other designs.. but the simple small square is still one of my favs
  #69
Old 12-06-20, 09:55 AM
OC3D Elite
I've still been brainstorming and focussing on the front fan tray. Taking the premade one previously and trying to make it more appealing. So far my attempts have caused the frame to lose the rigidity of the original design.
Not going to give up however as its still good practise for me measuring parts and designing on the fly. Very fun.
Started with this design and worked from there.
First issue i see which is a limitation on my printer skills is having the logo protruding from the base lacked accurate details. So I decided to cut into the base intead. furthermore, I didnt like seeing empty gaps between the fans so wanted them covered up.
Behold version 2.
Also in white
I toyed with the idea to use an ironing technique for the top layers, but they were not to my liking. What I have noticed is the finished/texture of the PLA thats in contact with the build plate has no lines, or less signs its a 3D print, so i flipped the connector upside down on the printer.
Also attempted to print the interior logo with white PLA. and tried one pair face up and one pair face down so see how the finish looked
printing face down gave a much nicer finish.
My next problem is the sticker on the back of these fans being orientated at different angles. So I wanted to make these uniform and even. Since I haven't decided which way up the fans will be yet (depends on routing of wires) I'll add the next steps after its assembled.
Using the same logo I created some Corsair fan discs
Corsair POG champ
As they were only 1mm thick, cutting the logo into the print didnt look right so I opted for making the logo cut right through the design.
That leaves the hideous corsair stickers still visible. I figured I would leave it on and instead find a way to cover it. Decided on some mirror vinyl I still had from a while ago.
As you can see the disc is slightly too small. So I have since reprinted them all 1mm wider (not pictured)
  #70
Old 12-06-20, 10:43 AM
WYP's Avatar
WYP WYP is online now
News Guru
Very nice. Well done.
__________________
_______________________________
Twitter - @WYP_PC
Tags
build log, corsair 1000d, water cooled
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
